- Joined
- Sep 10, 2021
- Messages
- 316
- Likes
- 1,458
- Thread Starter
- #41
Is it used to convert stereo movies into 5.1 surround sound output?Agree with Dolby Pro Logic II.
Hi there, can you pls advise what the bass management is like?
- bass management for all audio channels
That’s correct, stereo to surround like upmix.Is it used to convert stereo movies into 5.1 surround sound output?
Bass Management - frequently cut off for subwoofer.Hi there, can you pls advise what the bass management is like?
Also, may I know what devices will be common to be connected to the balanced TRS output? Thanks
If you have to ask what it does, maybe you should not be building an AVR or AVP…Is it used to convert stereo movies into 5.1 surround sound output?
Yes, of-course. @markus has written a very good summary: https://mehlau.net/audio/bass-management/Hi there, can you pls advise what the bass management is like?
I'm expecting this product to be a multichannel DAC and hopefully (because of the HDMI's) some sort of object-based sound format will be implemented, I could be wrong though. BTW, software exists that can drive the amp and enhance the 'spatial sound' feature if the hardware is lacking.What’s the point? There is no decoding for anything with height channels..
Well, then I guess you’ll first have to explain to @Fosi Audio what that ishopefully (because of the HDMI's) some sort of object-based sound format will be implemented
Dolby Digital plus -in short terminology Atmos.Well, then I guess you’ll first have to explain to @Fosi Audio what that is
I would imagine the more expensive licenced formats might wait until Fosi Audio get the basic 5.1 hardware working with the freely available formats. Just supporting HDMI-ARC + some basic configuration of a 5.1 channel amplifier makes a fairly complex product, trying to do too much in one product is usually a recipe for a bad product.Dolby Digital plus -in short terminology Atmos.
"No need for a thousand channels of Atmos"I am late to the thread but I totally would buy the first option: 5.1 AV processor. 7.1 or 7.2 would better of course. No need for a thousand channels of Atmos.
Setting levels is mandatory. Distance and timing is a plus.
PEQ is a very important. Auto room correction maybe in a future firmware upgrade.
I always heard that audio codecs licensing is a hell, so make sure you know what you are getting into.
As for adding amp channels into the product, then it is no longer a pre-amp and turns into an AVR. Lots of competition there from the famous brands.
What if Fosi teamed up with a company (in the near future) that is already licensed to distribute Dolby Digital Plus (or whatever proprietary format)? They both can co-develop a pluggable stamp-sized daughterboard to swap out the 5.1 module in their AC-3 capable amp/avr. I love the idea of just retrofitting my amp (to add new features ) instead of starting all over again.We all jump on opportunities like this, with loads of expectations and often go out of context.
Since beginning, this product was supposed to be a simple 5.1 channel DAC/decoder with basic DD/DTS decoding.
The idea is really good as there isn't any decent product that could do the same without spending money for either full AVR or AVP.
All right…What if Fosi teamed up with a company (in the near future) that is already licensed to distribute Dolby Digital Plus (or whatever proprietary format)? They both can co-develop a pluggable stamp-sized daughterboard to swap out the 5.1 module in their AC-3 capable amp/avr. I love the idea of just retrofitting my amp (to add new features) instead of starting all over again.
More importantly, stereo music.Is it used to convert stereo movies into 5.1 surround sound output?
Yes, agreed. I would like to add to your comment:We all jump on opportunities like this, with loads of expectations and often go out of context.
