Need advice Streamer/DAC
Tasmania
Hey all first post here
I am looking to add a streaming device and DAC to my main system (Audio Note Soro SE -> Audio Note AN-E) for use with Roon.
Looking to keep the total cost under $1000 for the pair if possible. Please shoot me some suggestions to look into.
Thanks for any advice / help
Brendan
DHT 845
Smsl sd-9
Smsl m400
Brendan.Harris
Tasmania
SMSL m400 looks interesting but blows the budget unfortunately. Still... worth keeping an eye on.
cheers
Brendan.Harris
Tasmania
CXN V2 reviews well too but like the SMSL m400 blows the budget.
I get the feeling the budget may have to be stretched...
Cheers for the suggestion
somebodyelse
If you're ok with used hardware, Roon can use the old Squeezebox devices as players. Most (all?) of them have digital outputs so you can add a better DAC if you like.
Brendan.Harris
Tasmania
Squeezebox I had forgotten all about those... Didn't they stop making them a decade ago?
Would probably prefer to steer away from older equip if possible.
Thank you for the suggestion though
Brendan.Harris
Tasmania
Would be curious to know more about the ifi zen stream if anyone has any experience?
Some say it is excellent others say it is broken? Not sure what to think about this unit?
rfernand
You may end up pleasantly surprised with the Pro Ject Pre Box S2 and the Stream Box S2. Fairly compact (wall warts, thou). No issues at all with Roon. DSD/MQA if you need them. Quiet headphone out should you be so inclined.
Brendan.Harris
Tasmania
More good options to look into thank you guys.
Like a snob I have tended to dismiss project in the past but it may be time to re-evaluate what they produce.
The Matrix mini was on my radar but I have been unable to find many people with first hand experience living with one and auditioning one in Tasmania is a non-starter.
Thanks again for the suggestions
somebodyelse
Time flies - it was almost a decade ago! Since then it's been used or diy hardware, although Polyvection have started selling inexpensive if slightly limited compatible devices. The Digi32 is the one with digital outputs but hasn't made it to market yet, and there are probably better options.
