Yes, I already said as much
. Can you tell me how you now connect the crossovers to your pre? You must have some kind of y-cable to split the signals, or have dual outputs on the pre?
Alternative setup could be:
CD player -> spdif -> SHD (-> spdif -> Larvey)-> pre
Pre -> DBX -> amps -> speakers
Pre -> DBX -> amps -> subs
Volume control is on the pre. Has less control on sub EQ, where is it probably more important. You might be able to loop back the sub pre-out back to the SHD and route that to the second set of channels and then again into the sub crossover. That would also give you sub EQ. Just needs a bit more cabling and a bit more effort to set-up. So like this:
Pre -> SHD -> DBX -> amps -> subs
