Is there a graph of output impedance someplace? Curious...
Perhaps fair to report that the impedance curve for the A-1 is when you set the tone control to +32dB at 23kHz. Why would you use that as representative of actual loudspeakers?I have already done it several times, so again -
View attachment 292267 View attachment 292266
It is a design flaw. Good amplifier must handle 2uF in parallel with 4ohm. Period.
More appropriately, we're talking about an extremely tiny niche of speakers, none of which will be driven at those powers at those frequencies. Assuming the measurements are correct (and I have a few doubts), an amp that does fine with 99.99% of speakers is certainly a good amp. I have three different Hypex (or Hypex licensed nCore) amps here and they do very well driving both dynamic and electrostatic speakers.
I've matched a sub-$1000 amp (March audio p252) with $11k speakers (Revel F228be), but they are an easier load than many less expensive speakers.Literally I am doing that. So I guess that is one... Price and rated speaker power handling are but two of many factors in determining what amplifier and speakers to buy and pair.
2uF. Sorry, I missed the typo. For that power sweep, I used 1kHz. One figure that was cut for length was THD+N vs frequency with and without the 2uF load- the overlay was perfect.However, they took a lesson at Hypex when designing the Nilai ....
You measured at 1kHz, Stuart?
P.S.: Image says 4R//2uF, text says 4R//4uF. What is true??
I got similar results with the NCx500.
Thanks. In case of NC252MP, there is an interesting dependence of the amp stability/distortion on capacitance value. I tried the load 4R7 in parallel with 2.2uF, 4.4uF, 22uF, 33uF at 1kHz. Though with high capacitances 22uF and 33uF the module behaves nicely, with low noise and low distortion, with 2.2uF and 4.4uF it goes crazy. Please see below. There will be a border line somewhere when the FB loop gets stable again. Test frequency is 1kHz, BW22kHz.
The same I can say about the NilaiI don't have a NC252MP on hand to see if I get the same- if one crosses my path, I'll try your experiment.
Class D still is unable to compete. Class D boom is all about business + marketing.
If this goes for all Ncore amps, then how is your measurement different from @SIY ’s who said he did not see any effect of 2uF // on THD+N vs frequency for Nilai en NCx500 in post #805?Unfortunately, the NC252MP, and I am quite sure it applies to any other amp from Ncore line, does not like much any kind of complex load, talking about distortion.
SIY's graph does show some degradation (but totally inconsequential) in the performance. For reference, below are the datasheet performance and SIY's measurements.
Guess I need to replace the NC502MP/NC252MP setup I've been using.It seems that now the older NC design need to be avoided.
That goes against what you said about the older NC needing to be avoidedOnly if you find any audio quality issue .
I can think of two big reasons right away:Why to want to buy an old design when the manufacturer just launched a new improved product?
After reading this thread, I would now choose a NCx or Nilai.
