OK, I an not too good with those 3 letter codes!
I do have had a new still sealed Squeezebox touch for many years which I have never got round to opening!
Surely after Tidal comes Tsunami?
Because Bob Stuart told them MQA sounds better.Lossless was invented ca 40 years ago with the introduction of the CD. And High Res came ca 20 years ago with the introduction of SACD. So why would one possibly want to listen to lossy formats while computer storage and Internet bandwidth are for grabs these days.
But no ones ever explained to me how a file that now sounds different than what the artist and producers mixed and approved in the studio can now be considered an improvement?
It may sound different, but better than the original master?
Just another lossy codec distortion IMO.
Bob Stuart is a British Audio icon. Loads of experience, and a success in his business model has made his controversial codec (MQA) puzzling.Who is Bob Stuart? Thank you so much for your reply! Agree for 200 %.
(Also wondering about the vinyl hype. Why would we possibly go back to the stone age besides nostalgia.)
Ah, I see. Thanks for your reply. To me MQA seems a marketing hype and should be a nogo for any serious HiFi hobbyists. Also fully agree with Sal1950 statement #86.Bob Stuart is a British Audio icon. Loads of experience, and a success in his business model has made his controversial codec (MQA) puzzling.
MQA is the Cod Liver Oil of streaming audio. It supposedly does something good for users while lightening our wallets. At best, it's largely ineffective.
At worst it leaves a bad taste in your mouth.
In either case, nobody (other than record label executives) asked for it.
https://www.meridian-audio.com/en/about-meridian/the-meridian-story/
Honestly I know I have a crude setup with just a smartphone with an ibasso dc03 dac and either a blon bl-01 or kzzs10 pro, but honestly there is a very small difference to none on a 320 kbps spotify and master/hifi tidal when I have the opportunity to try both.
The difference is small but it is there, especially in so called "problem samples". The trick is to listen for the background at elevated volume and in a quiet environment.Honestly I know I have a crude setup with just a smartphone with an ibasso dc03 dac and either a blon bl-01 or kzzs10 pro, but honestly there is a very small difference to none on a 320 kbps spotify and master/hifi tidal when I have the opportunity to try both.
Also, the shared playlists on Spotify are much more fun to explore.
I keept Spotify first to import some of these playlists into Tidal (which doesn't seem to work anymore)
Thank you Jimbob- Last time I tried I think it was blocked by Spotify ...You need 3rd party services like Soundiiz to import libraries, sync playlists between services etc.
There was a period a few months ago when Spotify expanded into Russia when they restricted connections. Been working fine for monthsThank you Jimbob- Last time I tried I think it was blocked by Spotify ...
But haven't tried it anymore since either.
Well if one needs to get up to some particular tricks to even tell the difference, but once you do you will never be able to un-hear it, however small the effect, the best thing to do is to ignore trying any of the tricks and enjoy the music instead, surely?The difference is small but it is there, especially in so called "problem samples". The trick is to listen for the background at elevated volume and in a quiet environment.
Once you have heard the difference, it is difficult to not hear it again.
THANK YOU!!!There was a period a few months ago when Spotify expanded into Russia when they restricted connections. Been working fine for months
Aye.Well if one needs to get up to some particular tricks to even tell the difference, but once you do you will never be able to un-hear it, however small the effect, the best thing to do is to ignore trying any of the tricks and enjoy the music instead, surely?
