staticV3
- Joined
- Aug 29, 2019
- Messages
- 12,771
- Likes
- 21,347
Why should I?
If I switch between the EU and the US, and put full volume the US version is very much higher!
When I asked:
You answered:are you getting the full 1.0Vrms right away?
When I then asked:Yes I got full volume right away
You answered:Are you sure that you measured 1.0Vrms at the Apple dongle output?
But apparently you didn't measure anything...
So no, even though the US version is louder than the EU version that you had before, you are not getting the full 1.0Vrms on Android, unless you first open UAPP/Hiby/Neutron, and set the UAC2 Hardware Volume to 100%.
You would know that if you actually measured the voltage like you said you did.
This is a problem that is separate from the EU limit and it affects all versions of the Apple dongle equally. The US dongle is not spared!
