Jean.Francois
- Joined
- May 31, 2022
- Messages
- 248
- Likes
- 945
Hello,
Miles Davis' "Kind of Blue", released in 1959, is often cited as one of the most influential jazz albums of all time.
However, an interesting technical detail about this album is the speed problem that affected some of its tracks. Initially, the album's master tapes were recorded at a slightly lower speed, resulting in faster playback and a higher pitch when the discs were pressed.
This problem particularly affected the first side of the album, where the tracks were played half a tone above their original pitch. It wasn't until 1997 that reissues of the album began to correct this problem, by adjusting the speed to reflect the musicians' original intention.
This difference in speed is also visible on the spectrum below, making it easier to measure the speed difference.
It is not possible to test the hundreds of versions of this album available, but this review contains over 30 versions, from 1960 to the present day, on all media (vinyl records, CDs, DVDs, SACDs, streaming), from mono to Dolby Atmos, with prestigious editions such as MOFI, Analog Production...
For this part 1 of the review, you'll find the first 10 tested versions among 30 versions: 5 Vinyl records (included MOFI, Japanese 2020 ), 2 SACD in stereo and 5.0 (included MOFI ), BNF stereo and Movo Fontana 1960.
We can distinguish two main categories in the rendering of this album.
A brighter rendering (attenuated bass, see spectrum analyse below), which is more faithful to the 1960 stereo version, and a more balanced rendering, which refers to the 1960 mono version we tested.
On the latest remastered versions, it is the balance of the 1960 mono version that is used for the stereo versions (e.g. MOFI), and retained for the mono versions.
Spectrum Ed 10 BNF Mono Fontana ref 682 059TL - 1960 (white) vs Ed 9 BNF stereo Fontana ref 885113 TY - 1960 (blue)
The stereo version has a clearer rendering, with a lower bass level (blue curve in the green zone)
Spectrum Ed 2 Vinyl ref : CS 8163 - NA-13-2011 - 2010 (white) vs Ed 1 Vinyl MFSL ref 2-45011 - 2015 (blue)
The MFSL version has a less clear rendering, with a higher bass level (blue curve in the green zone)
High-resolution samples are available for all versions HERE, as are all measurements (waveform, spectrogram, spectrum, spatialization, DR).
To follow, 20 additional versions like Analog Production's vinyl editions (33 rpm and 45 rpm), and other versions on CD, HDTT, vinyl, DVD, Dolby Atmos, Sony 360RA...
Enjoy listening,
Jean-François
Enjoy listening,
Jean-François
