Miles Davis – Kind of blue – Review – (Over 30 versions tested included vinyl records (MOFI, Analog Production, SACDs, CDs, Streaming), mono to Atmos.
Be careful when trying to glean that kind of information from discogs, as it has little quality control. There are many entries in there with duplicate catalog numbers. For example, there are 33 entries there for "Columbia – CS 8163". Probably more where people entered the UPC code instead of the catalog number, and then people will enter UPC codes as 1234567890 or 12345 67890 or "1 2345 5678 0".
A quick (i.e. "sloppy") attempt at uniqifying them gets me down to "only" 312 versions. Which is still mind-boggling.
I'm not trying to diss discogs, it's a wonderful resource which I use frequently. Just remember that it's S/N ratio is sometimes like a worn "well loved" 78 RPM record.
It does make me wonder, though: What recording has the most actual releases?
So it's rabbit hole time.
I was curious and I found that have two versions of Kind of Blue. Columbia/Sony Legacy Gold made in Japan 1992 - with the speed correction, and I also have a Columbia/Sony 1997 also speed corrected SACD with Multi Channel Stereo.
Now my question is: Can I rip the SACD and play multi channel through LMS Squeezebox or do I need an SACD player?
Anybody know?
Anybody know?
Can't rip it with a CD/DVD drive so nope for me.
Love it! It would be an odd month if I did not listen to it once.
One thing I really like is that the legacy edition, with studio outtakes, exists. That gives a clear window in the "sound of the room". Knowing that studio sound lets me judge whether some of that comes through with playback of the regular tracks, which it should, just a bit.
1959-60 has some incredible jazz releases, something must have been in the water... or air more likely.
Hello ,
Here is the second part of the Mile Davis “Kind of Blue” album review , which now contains the following 20 versions:
  1. Vinyl MFSL ref 2-45011 - 2015
  2. Vinyl ref : CS 8163 - NA-13-2011 - 2010
  3. Vinyl Clear ref : 19439802191 - 2021
  4. Vinyl Japan ref : SIJP 1020- 2020
  5. Vinyl Japan MONO ref : SIJP 1019- 2020
  6. SACD MFSL ref : UDSACD 2085 - 2015
  7. SACD Columbia stereo ref : CS64935 remastered 1997
  8. SACD Columbia multichannel ref : CS64935 remastered 1997
  9. BNF stereo Fontana ref 885113 TY - 1960
  10. BNF Mono Fontana ref 682 059TL - 1960
  11. CD Columbia-Legacy ref : CK 64935 - 1997
  12. CD Not Now Music ref : NOT2CD335 - 2010
  13. CD Box mono ref 88883756642 - 2013
  14. Amazon Music Ultra HD
  15. Vinyl Analog Production UHQR 33.33 rpm - 2021
  16. Vinyl Analog Production UHQR 45 rpm - 2022
  17. Japanese Vinyl ref : SONP 50027 - 1968
  18. CD Layer from SACD MFSL ref : UDSACD 2085 - 2015
  19. HDTT DXD - with speed correction - 2022
  20. HDTT DSD256 - 2022
The graph below compares the spectrum of the Vinyl Analog Production UHQR 33.33 rpm – 2021 (white curve) with the spectrum of the Vinyl MFSL ref 2-45011 – 2015 (blue curve).The two versions differ in their spectra. The yellow zone shows a difference in the low end of the spectrum (1 to 2 dB). The purple zone shows a difference in the midrange, with a higher pls level for the UHQR vinyl (up to 4 dB). The green zone shows the accentuation (up to 5 dB) above 14 kHz of the MFSL vinyl. The yellow arrow indicates a rise in noise on UHQR vinyl. The difference in mastering visible on the spectra provides two different listening experiences.
You can find samples from each version in high definition for listening and comparison, as well as all the measurements (weveform, spectrum, spectrogram, Dynamic Range…) HERE.
Enjoy listening,
I believe ripping these hi rez and multichannel discs is done with a PlayStation hack, but I haven't tried it myself.
Easier than the old PlayStation method.
Anybody know?
I use LMS on piCorePlayer at home and can play ripped SACDs with it just fine. When playing to a device that doesn't support DSF/DSD playback it automatically converts to PCM so that things just work.
There's lots of old hardware that can rip SACDs. I keep a couple of old Sony Blu-ray players that I picked up used at local thrift shops for under $10 each (one is sufficient, the other is a spare). If you want to start ripping SACDs the initial hurdle is getting the thumbdrive correctly formatted with the right software and figuring out the song and dance of when to insert it into the player. Once you've figured it out it's easy.
Hello ,
Enjoy listening,
My hats off to you.
The quality of your work is invaluable!
My hats off to you.
Thanks a lot!
This is the third part of the test of Mile Davis' “Kind of Blue” album, which now contains the following 33 versions:
Vinyl ref : CS 8163 – NA-13-2011 – 2010
Vinyl Clear ref : 19439802191 – 2021
SACD MFSL ref : UDSACD 2085 – 2015
BNF stereo Fontana ref 885113 TY – 1960
BNF Mono Fontana ref 682 059TL – 1960
CD Columbia-Legacy ref : CK 64935 – 1997
CD Not Now Music ref : NOT2CD335 – 2010
CD Box mono ref 88883756642 – 2013
Vinyl Analog Production UHQR 45 rpm – 2022
Japanese Vinyl ref : SONP 50027 – 1968
CD Layer from SACD MFSL ref : UDSACD 2085 – 2015
HDTT DXD – with speed correction – 2022
HDTT DSD256 – 2022
SACD Japan Stereo ref: SICP 10083 – 2007
SACD Japan 5.1 ref: SICP 10083 – 2007
CD from DVD Combo ref: CN 90887 – 2004
DVD stereo ref: CN 90887 – 2004
DVD 5.1 ref: CN 90887 – 2004
Streaming Qobuz Stereo 24/192
Streaming Qobuz Mono 24/96
Apple Dolby Atmos
Amazon Sony 360RA
Vinyl mono ref: WaxTime 772359 – 2024
Vinyl stereo ref: WaxTime 772359 – 2024
Blue Vinyl ref : 350202 – 2020
Music On Vinyl Vinyl ref MOVLP019 : – 2010
In short, we can categorize according to sound balance, with a brighter version and a version richer in bass offering a more natural sound balance. And also according to spatialization within the same sound balance.
To see these differences for yourself, you can find samples of each version in high definition for your own listening and comparison, as well as all the measurements (waveform, spectrum, spectrogram, Dynamic Range...) HERE.
Enjoy listening,
Jean-François
I love this album.
Of the versions I've heard, I like the MFSL Sacd most.
But i converted it to Flac 48kHz.
Does the alternate take of Flamenco Sketches justify re-ripping this to include it in my digital library?
Hello,
Here is the fourth part of the review dedicated Miles Davis “Kind of Blue”, which now contains the following 36 versions including the new versions from Analog Production Speed corrected vinyl (Ed34) , Analog Production Speed corrected blue vinyl (Ed35) and CD Audionautes Recordings (Ed36):
  1. Vinyl MFSL ref 2-45011 – 2015
  2. Vinyl ref : CS 8163 – NA-13-2011 – 2010
  3. Vinyl Clear ref : 19439802191 – 2021
  6. SACD MFSL ref : UDSACD 2085 – 2015
  9. BNF stereo Fontana ref 885113 TY – 1960
  10. BNF Mono Fontana ref 682 059TL – 1960
  11. CD Columbia-Legacy ref : CK 64935 – 1997
  12. CD Not Now Music ref : NOT2CD335 – 2010
  13. CD Box mono ref 88883756642 – 2013
  15. Vinyl Analog Production UHQR 33.33 rpm – 2021
  16. Vinyl Analog Production UHQR 45 rpm – 2022
  17. Japanese Vinyl ref : SONP 50027 – 1968
  18. CD Layer from SACD MFSL ref : UDSACD 2085 – 2015
  19. HDTT DXD – with speed correction – 2022
  20. HDTT DSD256 – 2022
  21. SACD Japan Stereo ref: SICP 10083 – 2007
  22. SACD Japan 5.1 ref: SICP 10083 – 2007
  23. CD from DVD Combo ref: CN 90887 – 2004
  24. DVD stereo ref: CN 90887 – 2004
  25. DVD 5.1 ref: CN 90887 – 2004
  26. Streaming Qobuz Stereo 24/192
  27. Streaming Qobuz Mono 24/96
  28. Apple Dolby Atmos
  29. Amazon Sony 360RA
  30. Vinyl mono ref: WaxTime 772359 – 2024
  31. Vinyl stereo ref: WaxTime 772359 – 2024
  32. Blue Vinyl ref : 350202 – 2020
  33. Music On Vinyl Vinyl ref : MOVLP019 – 2010
  34. Vinyl Analog Production (corrected speed) – 2025
  35. Blue Vinyl Analog Production (corrected speed) – 2025
  36. CD Audionautes – 2022
This new vinyl edition from Analogue Productions is particularly interesting. Indeed, this 2-LP release includes both the uncorrected and corrected speed versions — the latter being the one used for the UHQR edition. It delivers an excellent sound quality and, above all, with a significantly lower acquisition cost.
You can find samples from each version in high definition for listening and comparison, as well as all the measurements (waveform, spectrum, spectrogram, Dynamic Range…) HERE.
Enjoy listening,
Jean-François
Fantastic, Jean-François!
