Is MOFI definitely the best edition for the Mariah Carey – Merry Christmas album? Review – (Test: SACD, vinyl, UltraDisc One-Step and 45rpm, Atmos...)
Jean.Francois
Hello,
Mariah Carey's Merry Christmas album, released in 1994, features a mix of classic and original Christmas songs, including “All I Want for Christmas Is You”. To celebrate its 30th anniversary, MOFI has released 3 editions of this album, with an SACD version, UltraDisc One-Step vinyl disc and a double 45rpm vinyl disc.
Are the MOFI SACD and vinyl versions the new benchmarks? This is also an opportunity to compare the quality of the 3 MOFI formats for the same album (SACD, vinyl record UltraDisc One-Step, vinyl record 45 rpm) with original CD, Vinyl-book 30th anniversary, Tidal stereo and Dolby Atmos.
The waveform of the CD-1994 shows global Dynamic Range DR10, buts with DR8 for some songs (see waveform below).
The waveform of the MOFI editions shows a good dynamic range confirmed with DR12 (see SACD waveform below).
The graph below compares the spectrum of the Vinyl Record MOFI UltraDisc One-Step - 2024 (white curve) with the spectrum of the SACD MOFI - 2024 (blue curve).The two spectra overlap perfectly between 600 Hz and 13 kHz. Above 13 kHz (yellow zone) and below 600 Hz (green zone) the level is higher for the One-Step vinyl version, with a maximum difference of 5 dB. The sound is more physiological on the vinyl edition.
Spectrum  - Mariah Carey - Merry Christmas - Vinyl 33rpm MOFI (white) vs SACD MOFI (blue) -- S...jpg
The graph below compares the noise spectrum of the vinyl record 30th - 2024 (white curve) with the noise spectrum of the Vinyl Record MOFI 45rpm - 2024 (blue curve).The background noise of the 30th vinyl record was increased by 4 dB to match the MOFI records at the same listening level, in order to truly represent the noise level perceived during listening. It can be seen that the 30th vinyl record is noisier, with up to 6 dB difference below 2 kHz.
Noise  - Mariah Carey - Merry Christmas - Vinyl 30th (white) vs Vinyl 45rpm MOFI (blue) -- SMA...jpg
The Dolby Atmos version is a pleasant surprise, with a dynamic, highly spatial mix that gives the album even greater scope.
1994 - Merry Christmas [Dolby Atmos][262184441]  -  synthese.txt  [Atmos] --  9 (  7.7 --  9.8...jpg
For the 30th anniversary of this album, MOFI is hitting hard with 3 versions which are the best editions of this album released in 1994.
The SACD version is the reference in all media.
You'll find 2 samples for each support, so you can compare the different versions for yourself, as well as all the measurements you need to understand the differences in mastering and see the differences in surface noise on vinyl discs, here.
Enjoy listening,
Jean-François
Hello,
Enjoy listening,
Jean-François
Do you happen to have a digital copy of the Merry Christmas - Mariah Carey's SA-CD ISO? I loved the album, but unfortunately I don't have the means or knowledge to master the SA-CD. I'd love a digital copy of my SA-CD, if you'd be so kind. Thank you. Cheers!
Hello,
As I think you can understand, I can't provide any support I've used. Only the samples are available.
Thank you for your understanding.
