I just received my Sointuvas today. Here are a few photos. John
Yes...very weak magnets (good?). I'm about to do my 1st frequency resp. measurements - with/without grills. One thing I've noticed, they can play very loud without you noticing. Also very soft. On my minidsp Flex, I can go from minus 40's dB (soft) to the mid teens (loud) with everything sounding great. Very different from my previous speakers.Hmm you got grills with them? Magnetic?
People thinking of getting a bookshelf speaker to avoid excess bass but with these, bom bom matey you'll get some great rumble room modes in generalYes, the mid bass is surprisingly clean even when playing loud. And the low frequency extension is unbelievable. Plus a perfect balanced tonality and these speakers are really amazing.
I used a -1 dB straight line slope for target. Highest filter was 550 Hz. I used my tiny sub (REL T-Zero) for fill (100-150 hz). The sub has both a Hi & Low pass XO.I would use a target that extends the natural linear slope of the speaker into the bass area.
Hi yes there has been some issues and Alan replied to them back then, some controversies with reviews etc.Hello Matias,
Are you happy with the March Audio Sointuva AWG? Is it the 1 one or the new one. 2Nd model ? Because when I see the comments on ASR (2022) I see negative feedback in quality issues, no doubt the design is great and the sound above the size, and you seem to agree, but on the first model screw problems are reported, some bad ports mounted and with space between support and the wave-guide on the SB tweeter. I ask because I bought the ukkonen model last Tuesday. I'm a bit worried.
OK Matias thank you for your reply. I deleted my questions because after going through the feed I saw you were commenting the answers.Hi yes there has been some issues and Alan replied to them back then, some controversies with reviews etc.
But my unit is the latest AWG and working flawlessly. I love how they look and sound, so I am definitely satisfied and highly recommend them. Your Ukkonen should be awesome too. Enjoy!
You are right amazing sound. Finish is beautiful. The PTT8 ushindi is great very good work with the SB tweeters. The testers are right.Hi yes there has been some issues and Alan replied to them back then, some controversies with reviews etc.
Sorry if this has been covered, but why did Erin in his review indicate you had to sit 7 degrees above the tweeter level? We built a couple of pair of speakers with the same drivers, but bi-amplified with a Stormaudio processor and wondering if it is particular to the crossover used by March? Our version in the attached picture
Thanks. We are just getting started on setting these up. Currently have the crossover set for 2000hz with 24db Linkwitz Riley filters. The Stormaudio processor is the only product available that includes Dirac Active Room Treatment at this point in time and I am super pleased with the way that works. We are using 28" stands which puts the tweeter at ear level. Fun to experiment at this level of performance!
