Well the Topping L30 arrived today and I wasted no time hooking it up and comparing it against the ifi Zen Can. But before we go there I also have a Fiio E10 at my disposal to throw into the mix. Using it as a DAC for the comparison between the Topping and the Zen Can as well as a stand alone. I will also be using my Soundblaster Z Card on my PC at 70% out of the front output; rated as Very Good by Amirm (Personally, I like the Z card better than the Fiio E10 as a DAC plus you can EQ and SBX with it if you so desire).
https://www.audiosciencereview.com/...nd-measurements-of-sound-blaster-z-card.9127/
This is more of an objective test than a subjective one. I have no tools other than my ears and a lifetime of listening. I did not detect any differences in sound signature other than when I switched out the DACs, and in doing so it presented each of the DACs signature similarly. I did check for any audible noise on these amps when the music was paused and they were all dead quiet (unlike my Old airhead that literally scratched and clawed its way to louder sound). This test is an attempt to see which unit delivers the most power. The headphones used are the Sennheiser HD 660s and the Hifiman Sundara. All these amps are capable of driving these 2 headphones quite well.
The Fiio E10 had to be maxed out to keep up with the Topping, but the Topping won out with plenty of room to spare, but it had to do so at the +9 db gain setting, and of course the little Fiio was set to high gain as well. Before this test I had a Fiio K5 pro to see if it was just a size difference thing when comparing the Fiio E10 to the Zen Can. While the K5 pro did beat out the E10 it was more on the same level as the Topping, in fact it is a great value for anyone looking for a combo unit as it has a DAC onboard.
Now on to the direct comparison. When the Topping is (pretty much maxed out) at +9db and 4 o'clock and the Zen Can is at +6db and 2 o'clock they are the same. This is after much trial and error through many A/B scenarios. At the +12db the Zen Dac comfortably drives either of these headphones to insane levels, and there is another level after that +18. Now I may have a different threshold for listening levels than some of you but I do not listen to it blistering all the time, only now and again when there is a song like YYZ from Rush that takes me there. And there is nothing worse than running out of “dial” when that moment occurs. With the Zen Can you don’t run out of “dial”.
One more thing to consider is that this was all done via single ended/rca connections. When I use the balanced cables on the Sennheisers then it goes to a whole different level on the Zen Can that is truly not necessary for these headphones.
Finally, there is that BassX button on the Zen Can.......I know that I shouldn't touch it....but when I do it is really hard to go back to listening with it off, especially at lower listening levels. The only negative for me besides the look and the fact that it is un-stackable is that it cannot serve as a pre-amp for my desktop speakers.
As a side note I found that the Zen was louder using single ended vs RCA and that makes me wonder what is up with that.
