Looking for a good amp/DAC with LDAC transmit
skerik
I have an Audeze Mobius headset purchased mainly for PC use which features the LDAC Bluetooth codec. It's really the only way to use this headset wirelessly as the sound quality over base BT takes a deep nosedive. So I bought the well known Fiio BTA30 which is one of the few pieces of gear out there that seems to have a BT output featuring LDAC, as opposed to only an input.
I've now recently picked up a HifiMan HE-560 v4 and would like to also use it (in different circumstances) with my PC. The BTA30 can do this with an RCA to 1/4 adapter I got... but the output is a little on the low side. I guess the BTA30 amp is not that strong. I'd love to find a single device that can connect to my PC and support both headsets, which means having 1) a solid amp; 2) BT out with LDAC; 3) DAC with at least optical, if not USB input.
Searching around here and other places I'm coming up short on finding anything. It doesn't seem like this should be so rare, but that seems to be the case. Does anyone here have a suggestion? I looked at a couple of the Topping units but they seem to feature BT/LDAC as input only.
Zim
Kangarooland
I’ve been searching for what you’re seeking for months now. And the only option that I know of to do what you want to do is;
Topping D10s (Optical Out) -> BTA30 (Optical In) -> LDAC Transmit
Topping D10s (RCA Out) -> Headphone Amp
The BTA30 is so far the only desktop device that I know of to have LDAC out.
usern
I have looked for LDAC transmitter in the past and I didn't really find one. Good to know there is now BTA30 that does LDAC and also aptx LL.
S
skerik
I realized last night that I have an Emotiva TA-100 integrated amp sitting around unused, that has what's probably a very good quality headphone out, and a USB input. Since the BTA30 is only able to use Optical/Coax inputs for the PC audio, I might just split out for the HifiMan 'phones and use the TA-100 as an independent path. Then I can wait & watch to see if anyone comes out with the one device that will do it all... the precious, lol.
Another thing that would be REALLY nice is if Microsoft or Sony could come up with an LDAC driver for Windows!
A Surfer
The odds of your integrated amp having a good quality headphone section is actually pretty low. Typically resistors are placed between the speaker output and the headphone output.
GADGETMAN
Apparently the Aune 8 will have ldac out via Bluetooth.
