Liquid metal speaker cable - technological breakthrough
Rip City Dave
Portland, OR
This breakthrough is guaranteed to lift that final veil!
mansr
Hampshire
If mercury poisoning isn't your thing, what about Gallium? It'll solidify if the room is cold, but your kilowatt class A amps will take care of that.
Galinstan is a less toxic alternative to mercury that is liquid at room temperature (and a bit lower). It's an alloy of gallium, indium, and some other stuff.
Philbo King
The best wiring is no wiring. We ionize the air in the room enough, and the music signal flows freely through the room.
That could work, if you used high powered lasers to turn the air into plasma. Might have various drawbacks...
Doodski
We would be like roasting grapes impaled on sharp toothpicks on lit cigarettes in the microwave oven smoking away with sparks and corona balls (j/k) floating around.
Killingbeans
Bjerringbro, Denmark.
No need. If you just crank the voltage of the signal high enough it'll take care of the ionization on its own... with a few other drawbacks :D
egellings
The Aqueous Aureus line of Interconnects initially introduced over 5 years ago, was one of the first cables to use Contego (a specific ratio mixture of Fluid and Ferox). The Luminist Revision of the Aqueous Aureus improves the Fluid Ferox mixture! With the enhanced alloy conductors and the sleek hand crafted design, the Aqueous Aureus delivers some of the most breath taking performance for its price point! They are available in Single-Ended (RCA) and Balanced (XLR) configurations. If your system demands a custom configuration, please contact us. We're able to custom-build to fit your needs!
So now I have to worry about plumbing in my audio setup too?
Descartes
What a load, here for some who needs refreshing!
I find interesting that over the years the “Audiophile Rags” have become more and more subjective in theirs reviews! I guess that advertising money is just to good!
