UltraNearFieldJock
When to expect a release on vinyl? Vinyl sounds better!Sony's "Super Audio Check CD"
Galinstan is a less toxic alternative to mercury that is liquid at room temperature (and a bit lower). It's an alloy of gallium, indium, and some other stuff.If mercury poisoning isn't your thing, what about Gallium? It'll solidify if the room is cold, but your kilowatt class A amps will take care of that.
That could work, if you used high powered lasers to turn the air into plasma. Might have various drawbacks...The best wiring is no wiring. We ionize the air in the room enough, and the music signal flows freely through the room.
Tin (zinc would work too). Stan=stanium, aka tin.Galinstan is a less toxic alternative to mercury that is liquid at room temperature (and a bit lower). It's an alloy of gallium, indium, and some other stuff.
We would be like roasting grapes impaled on sharp toothpicks on lit cigarettes in the microwave oven smoking away with sparks and corona balls (j/k) floating around.That could work, if you used high powered lasers to turn the air into plasma. Might have various drawbacks...
So now I have to worry about plumbing in my audio setup too?
The Aqueous Aureus line of Interconnects initially introduced over 5 years ago, was one of the first cables to use Contego (a specific ratio mixture of Fluid and Ferox). The Luminist Revision of the Aqueous Aureus improves the Fluid Ferox mixture! With the enhanced alloy conductors and the sleek hand crafted design, the Aqueous Aureus delivers some of the most breath taking performance for its price point! They are available in Single-Ended (RCA) and Balanced (XLR) configurations. If your system demands a custom configuration, please contact us. We're able to custom-build to fit your needs!
Aqueous Interconnects
www.puristaudiodesign.com
