LG Hi-Fi Plus Windows 10 Problems
lixt1
Hello everyone:
I'm using LG HIFI PLUS with Windows v1903. The device connected with USB TYPE-C male to USB TYPE-A(Classic USB).
-I disable all usb power management.
-I disable onboard sound from bios.
-I tried USB 2.0 and USB 3.0 port.
-I tried to change regedit settings for LG HIFI PLUS.
-I also tried use with LG's driver and Windows's driver.
-Tried with Lubuntu linux distro.
and still i'm facing with these issues.
When i start my computer, device sometimes recognizedby windows(but no sound) ,
sometimes not recognized(ERROR CODE 43 windows says). And if its not recognized if i re-plug the type-c connector device works well or
sometimes windows recognize device but no sound comes from device if i replug 3.5mm jack or replug type-c then works well again.
No audio issue when its working.
I'm going to try with on-off switchable dedicated powered usb hub. What can i do ?
  • 4-port-usb-30-coklayici-hub-onoff-anahtarli-adaptorlu__1363952880028052.jpg
Most likely a hardware issue, probably a loose USB connection. Check the cable and the connector on each half of the DAC.
I'm on Windows 1903 and it works fine. Though I had issues on linux.
