As previous owner and fan of KEF coaxes (LS50, R3, Reference) I've been eying the LSX to replace the Sonos One's in my bedroom system.
But have been put off by the dismal reviews of the software and reliability.
I'm not planning on using the KEF streaming apps, but if you search for 'Roon has lost control of audio device' pretty much all involve KEF wireless speakers. And there are streams of horror stories about connection issues and bugs.
But when I spied a set on Amazon Warehouse for $600 I thought what the heck. I have a 30 day window to return them.
Mine arrived a couple of days ago and I guess I struck it lucky (ish).
Initial setup and firmware upgrade was a breeze. Easier in fact than initial Sonos setup.
The speakers were recognised by Roon directly and by Airplay (Roon and Apple Music) and music was forthcoming on demand.
I'll be streaming music, but direct connection to the optical and aux inputs also worked as advertised.
The audio quality is excellent. They have a strong family resemblance to the LS50, with similar strengths (coherence and soundstage) and weaknesses (frequency extremes). Because I listen to them at much lower levels than when I had the LS50s in my main system, I actually get better bass extension.
My quick REW measurements to work out whether to use room EQ via Roon were a good match to Amir's, although my treble droop came a little later.
It hasn't all been sweetness and light though. Whilst it was easy to get both speakers merrily playing via the wireless connection, I noticed that the slave speaker was occasionally (and very briefly) dropping out. Switching to the cable connection solved the problem but I'd prefer wireless for aesthetic reasons.
So I crossed my fingers and did a full factory reset. This time setup was just as easy, but so far wireless is working as it should.
I also have had the problem alluded to earlier where Roon reports that it has lost control of the audio device. Whilst I have numerous issues with Roon's network performance, dropouts and memory leaks, I haven't had this one before.
It only happened vis the Roon direct connection. Not via Airplay.
It also only happened whilst I was fiddling with Roon's DSP EQ settings, so I would sheet the blame at both Roon and KEF.
Given the price I paid I'm happy (if slightly nervous).
They are the only affordable wireless speaker I can think of with both notably better sound than Sonos and notably better aesthetics. The latter is crucial for me (and my partner).
For pure sonic quality I suspect the Neumann KH80 with a Sonos Connect or Wiim are superior. But they are small (good) and ugly (bad).
