Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 7,645
- Likes
- 9,540
So they're basically using the same material as the Nautilus or is it different?
I'd suspect they used Corian or any similar acrylic "stone" (yep, kitchen countertop going hi-end audio) if there was no "lightweight".cabinet is constructed from a lightweight composite material that is incredibly strong and rigid
Monitor Audio Hyphn is officially made of Corian tho.
It's very versatile. Corian itself is offcially thermoformable and there are similar acrylic compounds but liquid - to cast virtually anything.Corian comes in boards, a bit like wood. It is glued together and sanded like wood
My previous house kitchen boards were made of corian, I can tell you it's 100% repairable (even at the gray color, repair was impeccable, nothing left to know it was scratched) .Correct me if i'm wrong, but I understand that Corian comes in boards, a bit like wood. It is glued together and sanded like wood.
Fibrelass and that B&W Nautilus are cast fibreglass. Meaning there is a mold, and they push fibreglass and resin into the mold. It is then vacuum sealed until the resin cures, and then unmolded.
I don't know if you can melt Corian and pour it into a mold (i.e. injection molding). Plastic model kits are injection molded - the metal molds are expensive to make, as is the vacuum that pulls molten plastic through the mold. The metal needs to be heated during the injection phase to stop the plastic from solidifying and incompletely filling the mold. Making something as large as a speaker using this process would be horrendously expensive.
The way to tell the difference is to look inside the speaker. If you see fibreglass marks, it's fibreglass. If you see ejection pin marks, it's injection molded. I can tell you for sure that a complex shape like a KEF Blade or B&W Nautilus did not start off as boards of plastic or Corian, it has to be molded somehow.
I agree as you can see the also from the internal ribsI can tell you for sure that a complex shape like a KEF Blade or B&W Nautilus did not start off as boards of plastic or Corian, it has to be molded somehow.
being under paid and over worked
Archbishop, Pope, Vicar, TV EvangelistIf anyone knows of a job where your overpaid and under worked, be sure and let me know.![]()
Yea , ASR cheques are a rare thing , KEF don't pay as well as Topping but a man's got to do what a man's got to do, after all , We can't all have sugar mommy's...Talk to @Thomas savage!
Lots of people in my circle think "materials in their plastic deformation phase"If you use the definition of "plastic" in the deformation sense this is true but then mild steel is plastic in that sense!
I don't think many people think "materials in their plastic deformation phase" when somebody writes "plastic".
Definitely a molded acrylic (there are hundreds of types); however, it is quite thick. May contain fibers and other fillers.
I had the Perlistens, too, but not when I had the Blades which came to me later. Each was compared to the then resident Revels and both caused me to consider them for purchase. Although I chose the Blades (and I am not unhappy about that), I do regret that a Blade/Perlisten comparison was not possible.The Blades seem really good across all music. I found the Perlisten towers competitive for less money but no store I found had both Perlisten and Blades in them at the same time.
I thought Erin ended up purchasing them?He's in Alabama.
He was loaned the Blade 2s for the review, then returned them back to KEF. But his video of the review is worth reading/watching - a completely different take than the OP.
