unpluggged
- Joined
- Jan 5, 2023
- Messages
- 1,365
- Likes
- 1,685
This is nonsense.The s24 Ultra will not work with 3.5 mm earphone connectors
They're both following the same standards as Apple and UGreen, so you will probably have the same problem.Truthear and Moondrop websites do indeed sell dongles which could solve the problem.
Would either work with the others products?
Wow. Whilst I'm sure it's BS they don't deserve sales with support staff like that.The s24 Ultra will not work with 3.5 mm earphone connectors
Of course he isDavid specifically, is quite keen to sell me an Audioquest Dragonfly
Just for your information, there also seem to be problems with the Audioquest Dragonfly on the S24.Okay, my favourite hifi shop Unilet, David specifically, is quite keen to sell me an Audioquest Dragonfly which he reckons would do the trick. A bit pricy, and he did initially say I should try a phone shop. That sounds sensible, as I would be able to try any allegedly working option in the shop.
I did think last night that I am just cursed. Admittedly in a dim living room, I tried to take a picture on Zoom, of a lamp. Wouldn't focus, blurred image!!!!!
Faffed about this morning, and now it seems fine.![]()
That sounds like even if you buy something it's not guaranteed to keep working flawlessly. A Bluetooth adapter like the Qudelix 5K might be the best way forward.Just for your information, there also seem to be problems with the Audioquest Dragonfly on the S24.
In general, a lot of problems are reported with the Samsung S24 Ultra and 3.5mm audio.
The description of the problems is similar, often it worked at first and then stopped. There also seem to have been fewer problems with the first devices, but when the devices were replaced with newer models after a defect, the 3.5mm audio no longer worked.
The same problems are also known with the S24 Ultra with various desktop DACs, both expensive and cheap.
In some places it is described that it can work if music playback is started and then the USB-C adapter is plugged into the S24.
As the problems occurred for many people regardless of software updates, it could actually be a massive hardware problem. It's sad that Samsung is once again sitting it out without offering buyers a solution.
I can recommend the Qudelix 5K from personal experience, especially because of EQ.That sounds like even if you buy something it's not guaranteed to keep working flawlessly. A Bluetooth adapter like the Qudelix 5K might be the best way forward.
I still very much doubt that Samsung phones have some issues supporting USB class-compliant hardware. In my own experience, based on long-term use of first the Galaxy S10 and now the S23 Ultra, there is no problems at all. I tried to connect various audio devices, and everything worked flawlessly, starting with the Apple dongle and including the Qudelix 5K, Shanling M3s DAP, audio interfaces like the RME ADI-2 Pro, Zoom UAC-2, the Yamaha MG10XU mixing console, USB microphones like Shure MV88+, Rode Wireless Pro, Rode NT1 5th Gen, Zoom H1n handheld recorder (in USB interface mode).They probably think everyone should be buying their bluetooth IEMs instead of using wires.
The MOONDROP DAWN Pro is also just a USB dongle without Bluetooth.Quedelix certainly is far cheaper than the Dragonfly options. Cheaper again appears to be the Moondrop equivalent device The Dawn Pro.
I do note that Moondrop also appears to sell quite cheaply iem's with a USB connection. I think I'll just be patient. As always, you guys absolutely brilliant!![]()
Eighty year old! Deary me.Thanks Roland
Truthfully, I have been content with the Moondrop Chu and the Zero:2 via the One plus 5, straight out of the box. Eighty old ears, and all that.
Have you sent all the dongles back? If not- plug any you have left that havent worked on the S24 into the OP5 (Thats USB C isnt it? )Thanks Roland
I used to think that too and was of the opinion that they should be right out of the box, but that's hardly technically possible.Thanks Roland
