Is there any power headphone amplifier?
TS255
Hi all.
I am wondering if there is any headphone amp works like a power amp that can work with a pre amplifier?
As far as I know some amp like violectric 550 had direct mode that allows for a preamp setup. Is there any other ones?
Asking because I like my current preamp and just want to integrate headphone into my current speaker setup.
Thanks a lot ~
Hi all.
Thanks a lot ~
Dont think so but setting any headamp at the loudest gain and volume knob level you will ever need then controlling actual in play volume with your preamp will work fine as long as the preamp output voltage isnt higher than the headamp can take. Find a headamp with a high input sensitivity.
You can connect headphones to a poweramp speaker outs*, so kind of.
* You probably don't want to, plus you need to know what you are doing.
Almost all "headphone amplifiers" should have analog line-inputs.
If you have trouble finding one, try places that sell pro audio like Musician's Friend.
...Most regular hi-fi preamps have headphone outputs but the "quality" might be suspect.
