How to tell if an older amplifier will support 4ohm loads?
  • Thread starter Deleted member 69358
  • Start date
D
Guest
For the system I am putting together for my daughter, I think a FOSI amp would not be ideal and am thinking of getting either a used AVR or an entry level AVR. For the used AVR's how do you know if it will support 4ohm speakers?
staticV3
Every User Manual has a page with specifications at the end, which usually state the supported load impedances.
Blumlein 88
Many/most will also have a notation on the back saying whether 4 ohm, 6 ohm or 8 ohm minimum. A few a have switch for 8 ohm/ 4ohm operation on the back.
D
Guest
Some of them do not specify but have a "dynamic output" for 2/4/6/8 ohms
  • 2024-02-05 14_15_26-Manual_ VSX604S OM PIONEER EN _ Free Download, Borrow, and Streaming _ Int...png
DVDdoug
Too-low impedance is "reasonably safe" as long as you aren't using full-power. How loud does your daughter like to listen? Personally, I'd take the risk if you can find a cheap used AVR.
If you're lucky it will go safely into protection mode and shut-down when pushed too hard. If you are unlucky it might burn up, and if it was cheap you've lost a little money.
...I'm running big 4-Ohm (passive) subwoofers with an older "8-Ohm" amplifier. I can "shake the walls" but I'm not pushing it to the max. (I have near-by neighbors, and I'm not a kid anymore, and I'm not trying to blow my ears out!)
D
Guest
She is sensitive to loud sounds so will never play very loud. It is an old Pioneer pro-logic receiver 100wpc. Total cost should be around $40. Maybe I will rethink the speakers. She listens to records and spotify.
I so wish those Fosi amps had remote control and way to secure Bluetooth. Don't like that anyone can connect to them and start playing music.
