It was not bad up to about 5kHz, and didn't wildly different, but it's very hard to compare at higher frequencies.Thank you for that information. That makes sense, I would expect the accuracy to drop off dramatically above about 3K or so.
In another thread https://audiosciencereview.com/forum/index.php?threads/lets-get-honest-with-spl.39932/post-1407788I compared NIOSH on an iPhone to my proper sound level meter. It was close above 100Hz, below that it dropped off rapidly being about -6dB by 70Hz. So you can't use it for subwoofer setup.
I was impressed with the iPhone on pink noise and at 1kHz. I was expecting a bigger error relative to the SPL meter. The only issue was at very low frequencies where the departure was sufficient to not be trustworthy.In another thread https://audiosciencereview.com/forum/index.php?threads/lets-get-honest-with-spl.39932/post-1407788
I compared a couple of hand held SPL meters, and iPhone running Studio 6 Digital's $20 app on an iOS device and a Class 1 SPL meter. The iOS phone running the app was excellent for dBA and dBC measurements.
Apparently that while the iPhone mics are not accurate, they are very consistent. The Studio Six Digital team has an integrated correction filter for every model iPhone and that is how they can make the readings so useful for dBA and dBC SPL measurements.I was impressed with the iPhone on pink noise and at 1kHz. I was expecting a bigger error relative to the SPL meter. The only issue was at very low frequencies where the departure was sufficient to not be trustworthy.
