Ok sure, we agree I think. This is why in post #3, I suggested 88.2 or 96KHz is safer: these allow for a wider margin of error in applying the low-pass filter during recording and mastering.
Even so, if the mastering engineer has used an incorrect (or no) filter at whatever sample rate they've mastered it at, this will be a problem, i.e. no sample rate is high enough if the engineer uses a sufficiently poor (or no) filter.
And we don't have a problem in the first place if we're using properly mastered RBCD. Filtering at higher sample rates just tends to be harder to stuff up.
Yes, this process is a kind of self fulfilling prophecy: in first step during mastering we cut every frequency above some limit and then during reproduction we say "ok, no need to go higher as there's nothing above it".
But my question is this: if you have the non-sine signal at base frequency of say 18 kHz for which you would need say 5 harmonics to represent accurately would you be able to hear the difference between that signal and 18kHz sine signal?
We can agree that all 5 harmonics of that signal are above hearing range but my question is can you hear them if they are "bundled" in the base 18kHz signal?
I mean, if you can't hear the difference between non-sine and sine 18kHz wave, why measure the THD at 18kHz as you want be able to tell the difference anyhow. But on the other hand, if you can tell the difference, in that case you need to raise the upper floor from 22kHz (hence 44kHz in RBCD) to something higher.
