Help with system setup.
Silgalias
Heya folks.
I have set up a system to stream Tidal. It consists of an Amazon tablet HD10+ via USB to a Gustard X16 DAC which in turn goes into a Willsenton R8 amp.
Getting up every time I want to change a track is a pain so I would like to control Tidal from my smartphone but without losing any audio fidelity. I would also like to be able to connect via ethernet cable to avoid interruptions to the music due to downloading pauses.
I used to have my PC in place of the tablet but since moving house I have my PC in another room. Also we are now on solar so have to watch power consumption and the pc is a desktop and power hungry.
I initially got the Amazon Fire tablet thinking I could use Alexa voice control linked to Tidal.
Only to find that it only works in the US.
I have tried using UAPP with Bubble UPnP between tablet and smartphone but Bubble does not allow MQA.
Do I need to shell out on something like the ifi zen stream?
Is there a cheaper alternative to €400 on a zen stream?
Thanks
staticV3
The WiiM Pro has Ethernet and supports Tidal Connect. Whether it can output MQA to the Gustard, I don't know.
Edit: here's what the user manual says
S
Silgalias
Thank you. That looks like it will do the trick at less than half the price.
Would using the digital out to my Gustard bypass the internal DAC?
