Would it be possible to measure one speaker indoors (much less background noise) and try to shield it from above and the sides (a bit off from the speaker) with something absorbent so the room is more out of the equation and then measure from a meter away?
And then measure around 83dB or so (and higher if you have more background noise)? Because I am not a pro but I don't like the measurement from outdoors.
I don't know what others think but the measurement from outside looks off in the waterfall plot. But like I said I am not a pro.
You can create quasi-anechoic measurements indoors and even make a more modern spinorma out the it:
Quasi-anechoic measurements are a way to capture the 'real' frequency response of a speaker without the influence of a room. They are called 'quasi-anechoic' because they have the potential to get you really close to the results one might achieve with a non-reflective environment like an...
www.audiosciencereview.com
*But you can also still create an approximated listening window (LW) response indoors to be used as a generalized template to create your own shelving EQ by spatially averaging a bunch of measurements together as well.
Below I've combined indoor derived quasi-anechoic measurements (+- 60 deg horizontal and +-15 deg vertical of my coax S8 monitor) and separate in-room measurements across the whole listening couch (+-30 deg & 100x sweeps
rms averaged), also merging and comparing it side-by-side with another third-party reviewer's axial response to come up with some simple yet "tailored" HF shelving filter of my own:
Trace 5 (axial response) was extracted from the ff. graph from a scanned Resolution Magazine Review:
Yikes! super-duper blurred, but serviceable enough.
It ain't identical to my own very flawed (in-room) quasi-anechoic FR, so I figured why not use it just as an additional separate point of reference, too.
