Hedd vs Adam vs Presonus vs Powered speakers
Dreg54
Good afternoon! Please help me what to take to listen to music rock/blues/jazz in a regular room 12 m^2 (130 ft²). There is no opportunity to listen. I've been reading forums for a week now and just get more confused.
Dac Topping d50s or e30:
Presonus r65 / r80;
Adam T8V;
Hedd 05;
Adam T5V + sub Presonus T10 (or Adam sub 7 pro (8 is already expensive, but as an option))
Adam A3X + Presonus T10 or Adam sub 7 pro
Active speakers: Airpulse A100, (A300pro may when it comes out)
Maybe your option? my budget is up to $ 1000
Your budget is $1k USD? The Prosonus T10 is around $600, and the Adam Sub7 is $700. You're not leaving much room for speakers and a DAC.
That said, the Kali LP-6 are cheap and worthwhile.
That's a pretty small room.
I'll say get a set of JBL 305PmkII or 306PMkII and match them to the JBL LSR310S sub-woofer. With a discount sale, that would be under US$600 for the 2.1 set (306p MkII pair + 310S) .
Or as @pozz suggested, the Kali LP-6 would go for US$298 / pair now. Plenty of money left for an active sub.
But for such a small room, you probably won't miss having a subwoofer when using the 6.5" speakers suggested above.
Just one note about the Adam A3Xs, a typical DAC with a fixed output easily overloads the single-ended inputs causing distortion, the speakers have a convenient volume knob on the front and can be connected so that volume on both speakers can be controlled by one knob, but they don't help so you need some sort of attenuation before the speakers. Haven't yet tried the XLRs. Otherwise they are pretty good, the low-end is surprisingly good, they won't go down to 20Hz but I don't feel I'm missing much in a near-field setup.
The PreSonus Temblor T10 and Adam Audio SUB 7 PRO is 350$
Adam Audio SUB 8 PRO is 550$.
I live in Russia, I can order from Germany at that price. https://www.musicstore.com/ru_RU/RUB/-/-/cat-RECORDING-RECMONSUBW
I would like to buy speakers with a ribbon tweeter, I like how it looks, it's not usually
I read a lot that these are very-very good speakers for that price, but I would really like to try speakers with ribbon tweeter
Then the T5V is your best bet. It's the only one with published measurements by the manufacturer:
It also has a nice 5 year warranty.
You also have Eve Audio's SC205:
Red = 0° / Green = 30° horizontal off-axis
Orange = 2nd / Green = 3rd vs frequency response (red)
Red = 200Hz / Green = 1kHz / Blue = 5kHz
Which should be the next level in quality without being overpriced.
Thanks for the advice! Adam T5V + sub is one of the leading options
