Warning: Long post incoming! I did some tip comparisons for a friend but due to the immense effort involved, I feel like it is worth sharing here for Aria owners and buyers alike
Shorter bore = usually more sub bass
Wider bore = usually more upper treble
Short and wide bore = usually more v shaped
Longer bore = usually more mids
Long and wide bore = usually more airy and distant/thin
4 main factors apart from audio gear affecting how we can hear differently- first is our own ear anatomy (based on nuraphone's app my hearing is slightly less sensitive at the upper treble region- the diagram was shaped like a perfect upright roundish pentagon with a mild concave in the top left sloping face- meaning I might like a bit more treble air than others, but information from the app might not be transferable for IEMs/non-nuraphones -> needs verification). Second would be the listening level (the louder you listen to stuff the more bass and treble you hear according to the Munson Fletcher Curve). I personally listen at quite low levels, so take that into account. Third would be the seal (with better seal there would be more bass). I also hear different sizes of identical tip models differently and wonder if someone with M sized ears hear M sized tips the same way I hear S sized tips with my S sized ears, or if they hear them the way I hear M sized tips. Either way, this shows that small variations in tip sizes, such as between the same size of different brands, will inevitably affect perceived sound. Last of all is age (hearing experiences increasing roll of in the upper limit of the human audible frequency spectrum with age- mine cuts of at just under 18kHz currently; it was clearly above a few months back).
Disclaimer: Not going to note down every single tip I have and tried with the Aria in the past, since there are too many and many of which sound terrible (including Spiral Dots and ++ and all the other Spinfits). I didn’t expect the results of the CP100+ and Final Type E tips from the comparisons, because of prior negative auditory experience with nearly all other Spinfit tips including the CP100 non-plus version, and because the super narrow bore of the Final tips is usually an indicator of much darker, muted/congested sound. All tips tested should be in S size according to my memory unless stated otherwise and tested on the Moondrop Aria fitted with KXXS filters and NiceHCK GoldenFall SPC cable, driven by my Motu M2.
Narrowest bore tips:
Dunu/Fiio Red bore grey silicone- short bore (Decent soundstage, gobs of deep tight bass, smooth treble, slightly lacks upper mids and lower treble)
FAudio Instrument (In between Dunu/Fiio tips and AET08. Tonality of the Ostry with the presentation of the stock)
Final Audio 2021 Type E in Clear/Red with nozzle adaptor (Like FAudio above, but more focused on upper mids than lower mids, so less dark/heavy sounding. Very similar to the Dunu/Fiio, with a bit less relative bass and thus less dark. Still some bass congestion compared to wider bore tips, but it’s miraculously kept to the bass. Overall on the brighter side for narrow bore tips, with nice mid-treble detail)
Acoustune AET08 (Closer soundstage than Dunu/Fiio tips, more mids, less smooth treble)
Acoustune AET08A (Same as above but with more treble- splashy in nature)
Whizzer Easyfit Vocal tips (Sounds like the Ostry but with hazy treble)
*MH750 translucent white (Tonality close to the Ostry with the presentation of the Starlines, with slightly more upper mids. Bit more mids than the Final. More forward upper mids than stock hence less dark mid tonality with less treble shimmer; soundstage is similar but might be perceived to be more spacious due to said tonality. Given the price and quality of the IEMs it is packaged with I’d say it’s a worthy collection for a slight twist)
Close to stock bore width tips:
*Moondrop Aria Stock (Compared to Dunu/Fiio, a bit more upper mids and less bass, less dark sounding. Less bass pressure than Final Type E)
Ostry KC06A narrow/reference grey (Very similar to stock with a bit less presence, less upper mids but more treble- has its peak in higher frequencies? Upper mids is a bit too recessed for my liking. Feels less impactful but smoother, easier to appreciate sense of depth and space- similar to Tanchjim Cora narrow bore in this aspect)
Tanchjim Cora narrow bore (Very close to stock but transition between mids and treble is smoother with less sibilance/glare. Sense of immediacy and realism in the cymbals suffers a little though. Less perceived bass thickness which increases perceived soundstage width)
*KZ Starline M-sized (Wide soundstage due to its mid and treble presentation and reduced bass pressure, tonality overall slightly brighter than stock. Sounds like the MH750 tips with less bass and more treble. Lower to middle mids sound very similar to the Spinfit, bass is a bit less sub bass focused, treble a bit less smooth but more energetic and fun sounding. Price is *chefs kiss*)
*Spinfit CP100+ (More balanced sounding version of the Dunu/Fiio tips, soundstage is large and better presented than the Starlines’ in a more hemispherical fashion, with cleaner imaging and better separation. Would be perfect using huge curved monitors or IMAX screens lmao! Mids isn’t particularly loud or forward but its detail is surprisingly very good. Overall seems to best fit the Harman Curve in my head, pinna gain and all. Soaring upper mids with silky treble and weighty but not congested bass. Bass is probably the least characteristic trait- it is not especially tight or congested at my low listening level but is just there. At times I wish it had a tiny bit more upper treble, but it could be because of my relative insensitivity to that frequency region, at least according to the nuraphone app’s assessment, together with low volume listening levels which yields a lower perceived treble response in turn -> Munson Fletcher Curve. My favourite in said configuration)
Wide bore tips:
*BGVP A07 (One-of-a-kind pairing with the Aria in mentioned configuration. Vocal-oriented version of the Spinfit, bass is relatively less prominent as a result. Treble is smooth and clear but the velvety vocals take the forefront of the stage, which is great and has good height portrayal but slightly closer in proximity compared to the Spinfits’. Violins have a live, airy feel “
”. Works magic on tracks like “
” and “
” where vocals are slightly behind ideal in the mix, overly thin/bright, could be spotlighted, or where upper treble can be increased for extra air and liveliness. With “
” for example, where vocals are already warm and forward and air is sufficient, it still sounds great but the balance seems a little off for general track appreciation *Spinfit CP100+ sounds phenomenal on that track and also performs better on general pop songs where bass should be more prominent. The A07 tips is a vocals champ though; it handles everything from Disney to campfire songs and is the only tip which makes me feel like singing. I don’t listen to ASMR but I daresay it would be the best tip for that purpose as well. Given how well it complements the Spinfit I’d definitely keep both)
Acoustune AET07 (Less lower treble than BGVP A07. Soundstage suffers a bit as a result, but quite similar)
Philips Fidelio Grey bore (Compared to stock, main difference is in the treble- stock treble captures more lower frequencies and sounds more fleshed out. The Fidelio seems like it has slightly less upper mids too. Darker with less upper mids and more lower mids than the one size up)
Philips Fidelio one size up (Slightly brighter and tighter sounding than the similarly sized Starlines in M. Might have better lower mid transition, but somehow treble imaging does not stand out as much though there’s no shortage of it, possibly due to competition from upper mids. Upon repeated testing I find it overall too bright)
Green bore tips packaged with GR37 Anni or GR07X (Compared to Spinfits, less upper mids-lower treble and more congested sounding)
Acoustune AET07A (Mids too thick sounding)
KBear/NiceHCK 07 (Quite similar to Green bore tips but with a little more upper mids- lower treble hence clearer sounding. More bass and less soundstage compared to A07 tips)
Whizzer Easytips ET100 (Woolly sounding in the bass to mids, treble is clear though)
Whizzer HE01 Reference (Close to stock with greater sense of air throughout. Somewhat like the Ostry but effect is more exaggerated. Less upper mids than the ET100, and treble might be too unnaturally airy/splashy for some- cymbals seem to be lacking in the lower frequencies)
Forgotten IEM black with red bore (Close tonality to stock but more V-shaped with better defined bass and increased, brighter airier treble. Too much treble imo, especially considering I’m listening to it at lower volume and supposedly have reduced sensitivity towards upper treble. Audiophiles be audiophiles tho
FAudio Vocal (Too much bass and maybe lower mids, mids- especially upper- can be more forward)
Fiio F5 black (Slightly more natural than the F5 coloured bore in orange, but no strengths really worthy of note. Slightly shouty)
Fiio F5 orange bore (Like the Forgotten IEM tips but less smooth, with more lower mids and bass weight. A little congested/nasally sounding though, as if the pinna peak has been pushed up the frequency too much)
Azla Xelastec (More focused sounding in the than the Crystal. Treble emphasis is lower in the frequency region compared to the Short- less air and more bite. Quite unique sounding, somewhat unnatural and hard to describe. It’s a bit like bassy instruments only contain bass and cymbals only contain treble, while this sounds better integrated through other tips like the Forgotten red bore)
Super wide bore tips:
Azla Crystal Standard (Like the Spinfit with less bass and more treble. A bit too much treble air and bass isn’t very focused/solid, but soundstage is still good)
Azla Sedna Earfit Regular (Spacious, distant soundstage, but quite annoying to listen to because of all the extra upper frequencies present)
Azla Sedna Earfit Light (Sounds less annoying than the Regular version, wasn’t expecting this. Soundstage is still large but vocals sound a little thin and unfocused)
Azla Sedna Earfit Light Short (More focused vocals than the Light. Soundstage is less artificially wide but is very open sounding)
Azla Sedna Earfit Short (More balanced than the Light Short with added low end, a tad more congested sounding. Top end is still a little excessive due to the extra wide bore so sound can be described as V-shaped)
Concluding Favourites for this configuration of the Moondrop Aria using the Motu M2:
Stock S sized (Comes with Aria at no extra cost, good reference point XD)
Spinfit CP100+ S sized (Best all-rounder with great soundstage and separation and refinement)
KZ Starline M sized (Budget version of the Spinfit with same tonality and soundstage but less dynamism due to different bass region focus and also less refinement a.k.a. not as smooth and clean sounding)
MH750 S sized (Slight twist to stock with more upper mids and less upper treble. Comes with outstanding super budget IEMs as an affordable package
BGVP A07 S sized (Unparalleled pure vocal bliss for little. Nuff said)
