SOLD[US]: Schiit Magni Heresy headphone amp/pre-amp with short RCA cables
EchoChamber
Bought new directly from Schiit Audio in March 2020. Very little use. Includes a set of short RCA cables for a stack configuration.
SINAD of 119 dB per Audio Science Review measurements.
Asking $90 + $20 shipping - local pickup available in Northern NJ (Montclair area).
US Only, Paypal Only.
Specs from Schiit:
Frequency Response: 20Hz-20Khz, +/-0.04dB
Maximum Power, 16 ohms: 2.8W RMS per channel
Maximum Power, 32 ohms: 2.4W RMS per channel
Maximum Power, 50 ohms: 1.6W RMS per channel
Maximum Power, 300 ohms: 410mW RMS per channel
Maximum Power, 600 ohms: 215mW RMS per channel
THD+N:
High Gain: Less than 0.0014% (-97dB) at 1V RMS into 32 ohms
Low Gain: Less than 0.0002% (-113dB) at 1V RMS into 32 ohms
IMD:
High Gain: Less than 0.002% (-95dB) at 1V RMS into 32 ohms, CCIF
Low Gain: Less than 0.0006% (-105dB) at 1V RMS into 32 ohms, CCIF
SNR:
High Gain: Greater than 104dB, A weighted, referenced to 1V RMS
Low Gain: Greater than 115dB, A weighted, referenced to 1V RMS
Crosstalk: Less than -70dB, 20 Hz-20 kHz in either gain
Output Impedance: Less than 0.25 ohms at either gain
Input Impedance: 25k ohms
Gain: 1 (0db) or 5.5 (15db), selectable via rear switch
Topology: OPA1662 op-amp for voltage gain with local feedback, OPA1688 (8 stages) as output buffers with local loops, no overall loop feedback.
Protection: Standard failsafe DC power input and muting relay
Power Supply: “Wall wart” style 24VA 15VAC transformer, regulated +/- 16V rails with over 6,000uF filter capacitance
Power Consumption: 6W
Size: 5 x 3.5 x 1.25”
Weight: 1 lb
Aperiodic
With all due respect, seems a little high at virtually the same price as a brand new one direct from the mfr with a 2yr warranty...
Reactions: PSO
EchoChamber
EchoChamber
SOLD
Reactions: PSO
