Hold out no more: http://www.teoaudio.com/products/liquid-audio-cables/I am holding out until I can find a power chord and interconnects that contain liquid mercury as the signal transport. Until then the slow cooker it is for me!
Seems like TEO Audio does not know the first thing about the relevant audio science, especially loopback testing. An astounding feat of audiophoolery for our entertainment and the well-deserved tribulation of those who part with the money. Not liquid mercury though.Hold out no more: http://www.teoaudio.com/products/liquid-audio-cables/
Dead Sea salt?! They ain't gonna sound very lively after that treatment.Unfortunately these will not work because:
1). Microwave conditioning of power chord method will make you music "feel less alive and muted"
2). Conditioning power chord via toasting may be detrimental as your will lose the 3-D soundstage and it just adds unnecessary Veils
Slow cooking in a slow cooker you can add a pinch of Dead Sea salt or Hamalayan salt and that will help make the sound less bland/tinny. If you want some warmth and punch then add some Carolina Reaper pepper (not too much or your low end will become dominant). You can put a drop of Snake Oil and that always helps lift a couple of layers of veils "does no harm" to signal(1s will always be 1s and 0s will always be 0s).
They use reverse snake oil psychology in their marketing--but it's still snake oil.Hold out no more: http://www.teoaudio.com/products/liquid-audio-cables/
''EU users can use a plug adapter on the units without problems, as the units do not draw a current. They are designed to activate the internal technology with energy rather than current, thus creating both an electric and magnetic field. When activated the units effect the air molecules in the room, rendering them compliant to sound waves. The results are astounding, with improved resolution, sound stage and overall musicality. Listening room issues prior to installation of the ARNs are nearly obsolete.''I must thank you for that! I have needed that kind of laugh today! My favorite quote from that senseless diatribe:
"When you replace your existing interconnect cables with Liquid Cable, different recordings simply sound more different "
I was a bit dismayed when I saw that someone had discovered the Bybee stuff before I could post it,(I found that site years ago... absolute comedy gold!). Still, if you have not seen his entire product range I highly advise it. The further you scroll, the funnier it gets: https://bybeetech.com/products/#purifiers–diy-and-oem
Even better is this, um, "reviewer" who heaps praises upon ol' Bybee and his wares for the scientific miracle both they, and he, are: https://www.dagogo.com/bybee-technologies-quantum-products-review/
Then you have a short circuit in cognitive bias naturally, depends on if people think that this is a positive effect in practiceSo, connect Anode to my LEFT ear and Cathode to my RIGHT ear and then what?
There’s no magnetic field without current.''EU users can use a plug adapter on the units without problems, as the units do not draw a current. They are designed to activate the internal technology with energy rather than current, thus creating both an electric and magnetic field. When activated the units effect the air molecules in the room, rendering them compliant to sound waves. The results are astounding, with improved resolution, sound stage and overall musicality. Listening room issues prior to installation of the ARNs are nearly obsolete.''
Permanent magnets beg to differ.There’s no magnetic field without current.
Use the force, you have to believe or the magic will surely escape your grasp immediatelyThere’s no magnetic field without current.
The force is strong with this one!It is called "Magic Field" the veil lifting kind!!
Ah yes, a promise of veritable amusement for us."A veritable cornucopia of other innovations have yet to be released."
I was specifically referring to the purple prose.Permanent magnets beg to differ.
