Eversolo DMP- A10 @Purité Audio London
Purité Audio
Industry Insider
Barrowmaster
London
Well not quite yet, don’t know quite when or exactly how much either, sorry.
But the A-10 is now up on the Eversolo site,
It has some potentially useful features, dual sub outputs which can ne EQ’d and now the analogue input can also be EQ’d which are both useful and shows that Eversolo listen.
Reactions: pma
I felt very pleasant with A8 and still missing some part of it.....
Btw, hope you are doing well. My system is well settled and I'm enjoying.:)
Form an orderly queue:-
£3590 inc, available from the end of November.
Nice case. And isolated USB. That’s a good thing (I would say a must for a non-Toy DAC), unisolated USB + class I Safety design is a parameter (S/N) killer. The killer not revealed by single test component test via isolated AP I/O as performed here at ASR.
There is also this of course class A/B!
Just this teaser as far as I am aware.
instead on the pure Dac line there are no news? they always have Z6 and Z8 in their catalog. Do you know if there are any updates in sight? thanks
The EverSolo DMP-A8 now has a firmware update for room correction. With that said, is the A10 really worth the price difference?
In absolute sound quality terms there can’t be any difference between the three models 6/8/10 but each adds some potentially useful features, only you can judge whether those features are worth the extra.
The A-8 now has the auto room correction but not the sub ‘outs’, you can just use a Mini DSP processor to integrate your subs much less expensive.
With which resolution does the room correction work? Dirac Live does it in good implementations with 192/32, for example.
If I am only using the A8 as a DAC / streamer and not a preamp, why do the sub outs even matter? From what I know EverSolo room correction settings are "equalizer based" and use a mic to analyze the room and adjust the EQ accordingly. Would it then not listen to the base provided by the sub and then make adjustments?
The DMP A-10’s have almost arrived ( tomorrow ) wait until you see that illuminated rotating knob!
I will update the page with some in-situ photos.
Santa has arrived a might early,
Big box, foam packaging is substantial!
