Sorry for the necro post, but how about this approach.
Assuming MMM measurement technique and a 10 band PEQ.
We have three measurements, left, right, and left + right playing together.
Then in addition to the measured sum, we calculate the L + R sum as well.
We compare the two sums. Exactly around the 60dB line a difference trace is displayed. Of course the actual difference trace fluctuates around 0dB.
The difference trace represents what we expect to happen minus what actually happens when both speakers are playing together. This expectation I believe is the underlying assumption to the separate channel EQ method, and the difference trace might represent additional corrections needed to make this assumption reality.
We export the difference trace.
We take one channel and set out to EQ it to a simple -0.6dB target curve, just as an example. In this image the HF section was EQ-ed already. The focus is on the sub-250Hz portion.
We load the exported difference trace as a house curve. This changes our target considerably.
We EQ to the adjusted target.
We repeat this for the left channel.
The end result should now match the result of EQ-ing the measured L+R response to the original target with one correction applied to both channels. The difference being that the individual speakers now have the same in-room response as well. Not really sure how desirable that is to be honest though. With the other method you make your speakers do the same thing and let the individual room responses fall where they fall.
Of course all this can and should be verified with post-EQ measurements. Working on that. In the mean time I'd be most interested in your thoughts.
