Emotiva XT3 and RZ70?
Bassmister
So basically I got a good deal on Emotiva XT3 Towers for 1250 and XC1 center for 299. I also bought a X1700 from Costco for 399 and 2 Klipsch RP 1400SW from Adorama for 1500.
I made a couple mistakes. These speakers are power hungry and 4 ohms and the x1700h may not be enough to properly drive the speakers. I watched a review of Andrew Robinson and lower amps didn't work that well and they really need some watts to work. He reviewed the xt2 and not the xt3.
After watching that review I almost regret buying Emotiva and think I would have benefited buying the RP 8000F II instead.
I cannot return these speakers because they are just to heavy and I have to pay return shipping but I think I might be able to make these speakers work.
I'm returning the x1700H and buying a RZ70 and 5 Fosi V3 Mono Blocks. I want to use 2 blocks so I can bi amp the towers and use a single block for the XC1 center.
I feel connections and wires might make a little difference. I know most people say speaker wire doesn't make much of a difference at 15 feet but I think maybe this might help. I want to get 10 gauge OFC wire and connect the Amplifier and Speakers with bare wire and no use of banana plugs. I think the large wire would create more surface area and better ability to pass current. Maybe minimal difference but it all adds up?
The RZ70 has Dirac live and dual subwoofer support so maybe that connected to the amplifiers with 480ws going to the towers bi amp and 240w single amp to the center might sound better then just the x1700h when driving power hungry 4 ohms speakers.
I do plan to get a wifi power strip with surge protector that lets you monitor how much power is being used on a phone app to see how much watts are being used.
Then I will have a 3.2 setup.
After a month I want to upgrade to 7.2.4.
I have room for 4 surround speakers that I will get bookshelves and get them placed onto the wall. Only problem is the middle surrounds won't be even because there is no wall to place the speaker. They will be slightly uneven. Hopefully that won't be a problem.
Then the house comes with 5 height channels pre wired so maybe I could go with 5 height channels as well? 3 are above the TV and 2 in the back. I would only go with 5 if it's possible to have that many heights otherwise 4.
Any cheap recommendations for surround speakers and heights that are maybe refurbished and affordable and will pair well with the airmotiv xt3 and XC1?
The height speaker wire is 16 gauge. I was thinking I can wire 5 heights and 4 surrounds directly into the RZ70 without a amplifier if maybe they are more power efficient? But then they would be 8 ohms and the Fosi V3 Monos would be 4 ohms. Then the heights would be different speaker wire then the surrounds.
Confused on what to do next. Looking for a good match to the setup I already have. I bought a UMIK-1 as well for proper calibration but I have no clue how to use it. I am a beginner home theater guy.
Advice?
Reviews in someone else's house are useful, but ultimately you have to consider how things are working in your house. If it goes loud enough for your needs, then the AVR will be fine (obviously, more dollars being more features and more power).
The wires won't make a difference to power delivery (assume you are using sensible cross sections).
Just a quick reminder that you need significant power uplifts to go twice as loud. So 70, 90 and 100W amplifiers will all be roughly equally loud. 300W will be a noticeable uplift
good afternoon, in summary. how does the Emotiva XT3 sound? I want to buy one for music, I have 2 quad artera mono amplifiers
I know it's been a few months and several tariffs ago, but where did you get an xc1 at such a good price? I've been looking EVERYWHERE for the older model C1's or C2's. I've got a decent small budget...ok, downright next to nothing budget sound system that I'm seriously Jonesing to not just upgrade but finish! I've got an 55" LG OLED CX, which is attached toy Denon-4700H, then plugged into the Denon I have a Roku Express +, and a Sony ultrahd UBP-X700 4k Blu-ray player, then the attached speakers are 2x Emotiva T2+'s as LR, 2x Emotiva T0+s as my surrounds, and an SVS PB-2000 Pro for my subwoofer. I had $3k all set and ready to buy the center channel, whichever one, I don't care. I live alone in a small apartment. I also had my eye on some of those Atmos speakers anda6be even a couple of the di-pole, bi-pole speakers to REALLY surround myself with sound. But...when a family member comes to you in a panic asking if you can help them out, I'm here to tell you to only loan as much as you never mind getting back. Are there any other recommendations for a speaker that would blend well with the Emotiva and SVS in the lower echelon of price ranges? I saw a deftech center last night and had to tamp down my, "Oh, Look ,George! It's so shiny!" side and allow the, "Wow! This deal looks to good to be true, I should checkout some review and forums before spending $58 on a speaker that sold new for $300 or so," guy to take the reigns this time...and I'm glad I did. That Definitive Technology PC-1000 center channel was very tempting...until it wasn't. ‍♂️ Any suggestions?
