Mostly due to not having heard one that I find convincing, I still look on hybrid stats with suspicion...
Mind you, I haven't auditioned a set in a few decades!
Back in the day, I enjoyed the ML CLS & CLS-II but not any of the Hybrid models...
I have to agree that most hybrid ESLs never quite sound like a single, seamless speaker.
The only commercial hybrid ESLs I know of are from Sanders, Janzen and Martin Logan. Of those; I've only personally heard the older Martin Logan models, which in my opinion had good bass extension and punch but lacked seamless integration between the woofer and ESL panel.
The only full range ESLs I've hard are the Quad 57's and 63's. Their bass extended surprisingly low but wasn't as punchy as hybrid designs and was also a bit boomy and ill-defined at the bottom end, which I attributed to the diaphragm's drum-head resonance.
I've been an ESL designer and builder since 2008, and to-date I've built 20 pairs, in several configurations.
The challenge in full range ESL is mitigating the nasty-loud drum-head resonance. In a hybrid the stat panel doesn't have to play down low where the drum-head resonance dominates, but its challenge is achieving a seamless blend between the woofer and panel.
I wanted something different than the commercial ESLs I had heard so I took a different path; initially favoring hybrids with transmission-line bass, and now hybrids with segmented wire-stators and dipolar bass.
My latest and final hybrid ESL build sounds like a single-driver with the cleanest bass I've ever heard.
The key to seamless integration was using a low-Q [i.e well damped] woofer with low-inductance [i.e. minimal back-emf for faster transient response] mounted on an open baffle to match the ESL's dipolar radiation pattern. The low-Q woofer sacrifices deep bass extension to prioritize a seamless blending with the ESL, so subs are required for the bottom end (below 60Hz).
Building my speaker is more work than any sane person would attempt but I freely share my CAD drawings and all build info with other DIY'ers.
If interested; here's my website: http://jazzman-esl-page.blogspot.com
[/url
