Dac/Amp question with Genelec Speakers.
MarioSH
Hello,
I'm just looking to understand a little how this works, I currently have Genelec 8020 speakers which have Built-In AMPs, and they're plugged to a Topping Dx7 Pro Dac/Amp.
So since the Genelecs have built-in AMPs, is my Dx7 Pro working only as a DAC for them? Would it be better (If any difference at all) to get a dedicated DAC for them?
Thank you.
Chrispy
PNW
Isn't the DX7 just a headphone amp, not a speaker amp? More acts as a dac/pre-amp if anything for your active speakers I'd think....
M
MarioSH
I had the DX7 Pro before the speakers, I used it as a Headphone Amp before. Which is why I'm interested in knowing if there's anything I should replace it with for a better experience with the Genelecs (And if it's worth it?). I rarely use headphones now a days.
The screen on the DX7 Pro says "Pre" so I'm guessing it's working as a Dac/Pre-Amp.
staticV3
No replacement DAC would be worth the investment. Your DX7Pro is already fully transparent.
Rather, consider investing in a UMIK-1 or in room treatment.
Chrispy
PNW
Can't see why changing from the current unit would be of any benefit....
