Well, I own one XLS1002, so I did not have to check the manualIf you're buying a Crown XLS power amp don't imagine why the crossover feature would be of benefit unless powering both passive top/bottoms as intended, don't think the crossover feature applies to any line out feature. It's a power amp, what are you using for pre-amp/bass management otherwise? What are you using for pre-amp/processor?
ps sailor2005 seems to have more on the lineouts than I do
pps I misread sailor2005's post as to any crossover he mentioned, he's just mentioning a passthru for the sub and some limiting for the mains....not that great.
For the Yamaha I did have to check to extended manual they have on their website. It mentions a FULL+SUB mode but it only works for passive speakers and subs and then only for one amp per speaker/sub, so you would need 2 amps for stereo.
The Crown x-over thing was in case one wants to free the mains speakers from trying to reproduce what is going to be on the sub anyway and active subs have their own x-over. Some active subwoofers have line outputs with hi pass filters, in that case you can put the amp after the subwoofer and get the same result.
Let me clarify the x-over thing....
Powered subwoofers have their own x-over...so that routes the low frequencies to the sub.
The Crown x-over, if you want it.. if you so desire.. can route the frequencies you want on the mains.
Both ranges are taken care of
Ok..let me try to put it REAL simple.Let me clarify what is often called a crossover on a sub's own amp is simply a low pass filter, rarely an actual crossover (unless it has a way to high pass the signal to the upper range speakers of course). I have a variety of subs, including many diy subs using other than the typical plate amp on a consumer sub. What sub do you have that has an actual crossover for example?
Signal goes full range into the Crown (following?). If hi pass(with the frequency of your choice) is selected on the Crown, a hi-pass signal goes to the speakers(still with me?). The signal coming out to the link-outs of the Crown are still full range BUT when they go into the sub they are low-pass filtered. Hence you get 2 filters.
And by the way, the crossover in the Crown is not a pro or consumer thing..it is just an audio thing.
The magic occurs INSIDE the subwoofers because they have the filter!!! You just said that the subs have low pass filters. They low-pass the full range signal that goes into them.Well that's an interesting description except for the part that you say the the link-outs of the Crown are full range but somehow magically change when going into the sub....methinks you have a gap of understanding here.
You only need to send a low-passed signal to the subs when they DO NOT have that capability.
I don't need a clue when I already got the answerLOL you have no clue.
@Chrispy and @sailor2005 please the bickering isn't helping the original poster.
Neither amp is setup optimally as a stereo amp to connect two stereo speakers and a sub.
If the source component has two analog outputs per channel, the easy way is to configure a high pass function on the amps for the stereo speakers and use the built in low pass filter of the subwoofer input.
It also might help to know which exact sub the original poster is going to use. Some of those will allow stereo input, and will do the crossover and high pass the signal onto the amp for the stereo speakers. That would also work with either of these amps set to full range operation.
It does appear the Link Out on the Crown could be used to send the full range signal onto the subs. In this the link out goes to sub, and the Crown is set to a high pass function for the stereo speakers. The manual however is less than fully clear about what happens on the Link out.
I don't think it will necessarily compromise the sub setup. Subs generally are made to use full range input. It doesn't hurt them. I'd like to know if the Link outs are buffered or just a pass through. If just a pass thru you are getting the same effect as a y connection at the source output jacks. Which may be bad since the input impedance is likely to be only 5 kohm as seen by the source component. Which I suppose is what you mean by compromising the setup.I never said it was suitable as some sort of amp for integrating a sub, sorry if it came across that way. I think it's somewhat lame to compromise sub setup to accommodate gear not intended to incorporate one, tho.
