Tim Link
There's more going on with sound in a room than just modes. Frequencies that aren't associated with a mode still bounce around. Measuring the clarity of the upper bass and lower midrange before and after treating the corners can explain a lot more than just looking at the frequency response, which isn't always greatly changed by treatment.
Amroc room mode calculator is a cool tool, but real rooms do structural things as well, so the actual results are not always what is predicted by models that don't include that factor.
The cornerless room thought experiment is interesting, and if you model waves bouncing around in a room it becomes obvious that just treating the corners alone is not optimal. It's generally a good starting point. When setting up my current room I did some clap tests while it was empty, and got a strong, buzzy flutter echo. When I started to bring things in I first just assembled one of the floor to ceiling speaker grill frames and set it in the corner. This is just wood but it broke up the shape of that corner. I tried the clap test again and could not hear the flutter echo after just disrupting that one corner. I had imagined the echo as bouncing back and forth between the parallel walls, but apparently it was a longer delay than that, involving sound traversing forward, until getting to the front corners of the room, and then traversing back toward me, bouncing back and forth multiple times before reaching my ears again.
