Here's the CBT standing.
Do you guys like the finish? It's matte white and American walnut matte. The drivers are black by the way. Tweeters are glossy black and midbass/woofer is matte black.
Had glossy black with maple veneer as a second option. But either all black painted or combined with walnut is also something to consider. Offering two standard ones is likely enough, but hopefully with the option of custom finishes with pre-ordering.Yes, but for home theater would prefer darker. Perhaps baffle in black and the cabinet in walnut?
Cool stuff! Where in Norway are you located? I'm in the Oslo area and would love to hear a pair of these some day! Not that I'd ever be able to afford it though, but stillHere's the CBT standing.
25 minutes drive from Bergen down town.Cool stuff! Where in Norway are you located? I'm in the Oslo area and would love to hear a pair of these some day! Not that I'd ever be able to afford it though, but still![]()
www.oslohifishow.no
Ah yeah Bergen is a bit too far away, but a hotelroom in Asker might work! The CBT should take the room a bit out of the equation thought shouldn't it?25 minutes drive from Bergen down town.
May bring the CBTs to the show in Asker in March. But obviously a small hotel room isn't the best for demoing.
OSLO HIFI SHOW | Oslo HiFi Show
www.oslohifishow.no
It greatly minimizes vertical reflections. There are hardly any audible ones. Horizontally the dispersion is wide. While it's constant/uniform in the horizontal plane, it will obviously cause early arriving reflections. We will treat those though, but treating for many seats is tricky.Ah yeah Bergen is a bit too far away, but a hotelroom in Asker might work! The CBT should take the room a bit out of the equation thought shouldn't it?
Yeah you only have to deal with half of the reflections which is nice. And as far as I've understood they also have a wider sweet spot as well?It greatly minimizes vertical reflections. There are hardly any audible ones. Horizontally the dispersion is wide. While it's constant/uniform in the horizontal plane, it will obviously cause early arriving reflections. We will treat those though, but treating for many seats is tricky.
But we may only bring the Vera Audio Coherence 12 speaker. Not sure it's a good idea to bring both.
Yes, sound doesn't change much anywhere above the Schroeder frequency due to the constant directivity and less than 3 dB loss per meter. But a larger room would have been much better. Might bring both.Yeah you only have to deal with half of the reflections which is nice. And as far as I've understood they also have a wider sweet spot as well?
Personally I'd vote for you to bring these, will probably attract a bigger crowd, they're really interesting speakers imo!
Yeah, it seems to me the center channel would run hot...![]()
(As you can see, that was acceptable for a spring/summer review but not a viable permanent solution.)
This depends. The illustration below gives the answer for a ground plane CBT.I am curious about which direction represents the apparent source direction for the CBT speaker.
When you consider that there is an acoustic 'mirror image' of this speaker below the floor level, it seems to me that the apparent midpoint/source is where the speaker touches the floor.
Surely the speaker doesn't sound like the sound is firing up at the listener from the floor level?
And, if the apparent source is not where the speaker touches the floor, why is it not so, and what is the true apparent source height?
Looks can be deceivingthe tweeters look like these:
https://www.parts-express.com/pedocs/specs/285-103-dayton-audio-ce32a-4-specifications-2940.pdf
Those are midranges. Not that I doubt you saw them used that way.the tweeters look like these:
If each doubling adds 3db, and you have what, 20 of them?Those are midranges. Not that I doubt you saw them used that way.Also only good for about 82dB SPL each. Best used in a tuned box as a cheap computer speaker.
Yeah, they say '20k'. That's true if you consider 65dB SPL at 20k useful.
Well, while it does increase the maximum output, do you really want the maximum output being the "minimum necessary output"?If each doubling adds 3db, and you have what, 20 of them?
