Dangit you beat me to it @Blumlein 88
You could get a pair of these if it is a problem (it isn't always).Uh oh, bad juju. That would red flag it for me.
Yes, with 300w/ch on tap I would be scared to crank it up w/o the subsonic/rumble filter.Sucks
Can you you help me understand this recommendation a bit more. There is much I don't understand about amp specs, but comparing the power(380W@8, 480W@6, 4 and 2 Ohms not listed) with (for example) the March Audio P701(400@8, 700@4, 1200@2), the P701 seems to be a much better amp for $1,700 less. Even the P502 seems to outdo the Benchmark a bit at 1/3 the price. Of course, I'm making a few assumptions:
1. SINAD Difference (135dB vs 128dB) will be inaudible
2. Frequency Response difference(0.1Hz vs 10Hz) will be inaudible
Not sure if all of those are 100% true(especially #2), but going based off those for now, I would assume that they will sound equal at low to moderately high volumes, but the P701 will sound better at high volumes. I'd guess that the extra performance from the March amp will only be noticeable at high volumes, but it's still an audible advantage, and in this case it's also cheaper. I don't read many amp reviews around here(read 1 I think?), so apologies if this has been covered in one of those threads. I mostly just read the speaker reviews and general discussions.
Those are a bit of a difficult load:
"My estimate of the Sabrina's voltage sensitivity on the tweeter axis was 88.2dB/2.83V/m, slightly higher than the specified 87dB. Wilson specifies the Sabrina's electrical impedance as 4 ohms, with a minimum magnitude of 2.53 ohms at 139Hz. My measurement of the impedance is shown in fig.1: the value (solid trace) varies between 4 and 6 ohms between 250Hz and 4kHz, and the minimum magnitude is 2.44 ohms at 135Hz. However, there is also a combination of 4.44 ohms and a capacitive phase angle of –58° at 72Hz, a frequency where music can have considerable energy; this will place a significant demand for current on the partnering amplifier."
https://www.stereophile.com/content/wilson-audio-specialties-sabrina-loudspeaker-measurements
The speakers are not a "difficult" load in my opinion.
Yamaha has an AS-1200 on the way and a nice Technics SL-1500C should get you in under $3K in the US. No messing around with pre/power/phono stages, there is one in the amplifier. Your re-sale on these two products down the track will always be very good should you decide to move to something else.
After cranking up a Carver M1.5T with Cornwalls and having the phono feedback nearly shred the woofer when I was across the room from the pre I've been very careful since. It gave me a healthy respect for how tough a Cornwall is. It was pretty loud.It's generally not a big problem unless you have a really rotten turntable or a shocking arm/cart resonance.
Now there are people telling him to sell the Wilsons, buy some Revels
I suppose I'm a fundamentalist in believing that the desideratum of all this is better sound quality. If the goal is to have expensive stuff to impress middle-aged men, well, many of us used to be on the forum with that focus, and we were banished.
The only fundamental at ASR is if you don't drink beer I don't/can't trust you .. unfortunately Amirm doesn't drink beer ....ASR is becoming fundamentalist.
Anything not on the approved gear list must be banished.
Humm ... wood grained cabinetry -- reminds me of the '70s.This has it all in one box. Very nice Sabre DAC, mm phono preamp, multiple digital inputs, headphone amp and remote control in a small package. Also available in piano ebony. 14 inches by 14.24 inches by 4.3 inches tall. About 36 cm x 36 cm by 11 cm.
Nova 300 with 300 wpc 8 ohms and 450 wpc 4 ohms for $2199. Leaves money for the TT.
https://www.peachtreeaudio.com/collections/amplifiers/products/nova300
Does that mandate others follow the same decision tree?
[emphasis added]I know it's not what was asked, but arguing about March versus Benchmark amplifiers is picking nits when one of these very well-engineered amplifiers will be powering loudspeakers with, shall we say, suboptimal performance notwithstanding their high price.
"It's just too big it's not natural, at least start slow " .., I began receiving stern warnings from a gynecologist
Speak for yourself, some of us were buying expensive stuff to impress women. 30 years and I have yet to find one impressed, but there is still time.
I began receiving stern warnings from a gynecologist after posting a factually correct statement about the provenance of a high-end audio company's amplifiers, which were rebadged $200 Chinese desktop amps.
No, but "OBGYN" was part of his forum handle in those days. I thought it was a very memorable and unsettling thing to have as part of one's forum handle.He just threw gynecology into the midst of an audio discussion?
