This may sound like a question with an easy answer from Captain Obvious, but what is the correct way to wear over the ear cans?
I ask because with every set of over ears, I have experienced a soundstage that seems centered toward the the rear and top of my head. Like I'm standing a few steps down, in front of center-stage with my back turned to the music source. On certain tracks with unexpected ambient noises/sounds/effects, I have actually turned around to check for things behind me.
If I pull the cans forward on my head I can move the soundstage to middle of my head, but my pinnae are definitely being pulled forward, and there is some discomfort after awhile. Height wise, it still sounds like I'm low.
If I lengthen the arms and wear them lower, I lose the seal of the cups at the bottom.
Funny thing is that on phone calls, everything is better. Voices sound like they are centered right behind my eyes.
So, am I wearing them wrong, or am I just s**t outta luck?
I need the closed-backs to keep noise leakage to a minimum.
I primarily listen over BT (convenience and conference calls) using Apple Music or Spotify.
No known hearing deficiencies other than topping out at 13K on my last hearing test (age I'm guessing).
I don't have any issues spatially locating a source of a noise.
Thanks
Thanks
