what?Strange how it went from a bunch of really great headphones to the low end stuff again.
ED1Aneed a tranporble AMP/DAC for these close-backs.
The close-backs are mostly for "public use"
Thanks.ED1A
I can greatly recommend you the iBasso DC03pro such a good one !!I need a tranporble AMP/DAC for these close-backs
So its going to be your portable HP?And that is powerful enough for the Aeon 2 Noire?
Thanks, I will give it a look.I can greatly recommend you the iBasso DC03pro such a good one !!
Yes,So its going to be your portable HP?
maybe not loud like your desktop setup but yeah according to the specs.And that is powerful enough for the Aeon 2 Noire?
you are right this one is top notch but more pricey depends on your budget but the dac/hp specs are excellentThe Topping G5
1200mw @ 32 for portable with a battery its very big powerThe Topping G5
Exactly. And it has Bluetooth included.1200mw @ 32 for portable with a battery its very big power![]()
More power need more juicebtr7 880mAh vs 4000 for the Topping![]()
I need a tranporble AMP/DAC for these close-backs.
The close-backs are mostly for "public use".
I have Topping E50 II + L50 II for mine HifiMan Sundara.
Because wired headphones are better :-SWhy not go for wireless (NC) headphones then ?
