Clear/Transparent sound dampening?
Borteese
I'm planning to make a speaker cabinet out of plexiglass, and have run into an issue. Is there an internal sound-dampening solution (eg. polyfill) that is visually clear or transparent? If there isn't one truly effective solution, is internal reflection truly as bad as people describe it to be? Thanks.
fpitas
Northern Virginia, USA
I can't think of anything even vaguely clear. Dickason shows results with and without fillings and wall coverings in his Loudspeaker Design Cookbook. It's a big deal. Are you substantially bracing the plexiglass? It's a pretty flexible material.
DVDdoug
A different idea - Some stuffing material can probably be died to make it more "interesting" or to match your decor.
Count Arthur
I think what you want might be:
There are some glass speakers, but no internal sound-dampening: https://www.waterfallaudio.com/en/collection-glass-speakers/
Paul Ebert
Depends on the box. Sealed = Yes; ported = probably; open baffle = obviously, not applicable.
Maybe do a TL and cover the walls with some sort of transparent soft gel?
fpitas
fpitas
kemmler3D
San Francisco
No, not really.
It can be pretty bad, although resonances are arguably worse than lack of damping. The speaker will be worse than if you used damping material, but it may not be unlistenable or anything.
If you are doing one of these "clear" speakers, and you want it to sound good, you're going to need some very thick pieces, and you're going to need to pick your dimensions carefully. Keep in mind there's no way to eliminate internal standing waves, but you can choose dimensions so the harmonics don't line up.
fpitas
As much as audiophiles go on about transparent equipment, you'd think there would be clear damping materials :oops:
kemmler3D
San Francisco
To give a more thoughtful reply here - the only thing I can think of that might be remotely useful as damping and is at least semi-transparent would be some kind of aerogel. https://onlinelibrary.wiley.com/doi/10.1002/adem.202201137 - however, I think they are very expensive and probably not that easy to work with compared to more normal materials. Looks like about $3/ml on Amazon so I think that might blow up the budget...
Sokel
Double sided with some liquid in between :p
Seriously now,previous post comes close.
kemmler3D
San Francisco
I've looked into liquids as damping layers for enclosures... I didn't keep notes but IIRC they wouldn't work well because they tend to transmit sound pretty well.
However, you might be on to something! If you could find a liquid/gel that was highly viscous and also remained transparent (think green glue, but clear) then it would probably actually work fine. Constructing it might be a b**** but there's no reason a layered design couldn't work. It's actually pretty common to do constrained layer damping in DIY speakers using various adhesives that don't solidify. So the trick will be finding one that's clear and stays clear...
It wouldn't be as good as filling the box with wool, but it would be better than nothing. It would also reduce the penalty from not doing bracing.
Sokel
When I thing of crazy stuff I always try to imagine what would be to have a double-sided around but with vacuum created inside them.
It's not difficult I think,and sound from the inside would be difficult to escape it.
HarmonicTHD
Dampening usually relies on small particles / fibers rubbing against each other and converting sound energy into heat, which then gets dissipate. That makes them inherently opaque. Sorry no free lunch.
fpitas
That much is clear.
/I'll let myself out.
RayDunzl
Central Scrutinizer
Riverview FL
Why are your speaker cabinets transparent?
So you can see what's inside!
What's inside?
Nothing!
kemmler3D
San Francisco
A vaccuum layer would actually be incredibly good for isolation, I ran the numbers once and a basic thermos' vacuum would attenuate the transmitted sound by something like 100dB.
I have NO idea how to build a speaker enclosure with a layer of vacuum, but I would highly applaud anyone willing to try it. I personally think it would be extremely difficult...
Sokel
I would imagine basically two boxes (one of them smaller of course) ,one inside the other.
Some bracing in between them to maintain the distance,really good shielding and a vacuum pump in the end.
