- Joined
- May 18, 2020
- Messages
- 1,285
- Likes
- 2,941
Off topic, but ... what? You? Fashion? The entire board wants to hear about this ...... having spent my life in all facets of sales, from HiFi to houses, fashion to furniture ...
Probably one of the worst examples of this are companies selling led overhead light fixtures that require the customer to replace the whole fixture when the bulb no longer works. How about get a regular fixture and buy the LED bulb separate? The big box retailers also carry fixed 50 foot LED strings for Christmas. Defeats the purpose.
I wonder what is the life time of the capacitor in the output LC filter of almost any class D amp. If we consider usual values L = 20uH, C = 1uF and switching frequency Fosc = 420kHz, then the output filter capacitor is a subject of permanent high ripple current with high di/dt, this with non-zero ESR makes considerable power loss to be dissipated. The capacitor should be polypropylene impulse type and even then the ripple current is of concern. Any long-term experience with this here? Please see the explanation below:
L1 and C1 make the output filter
The plots show voltage before the filter, v(out1) with +/-30V amplitude, output voltage v(out) across the load R4, current through capacitor i(C1) and current through load i(R4). Please note the amplitude of capacitor current and the ripple current that will be there even at v(out) = 0.
LED bulbs are sold and they are replaceable like incandescent & florescent ones are. You don't toss the whole LED lamp fixture at replacement time.
Another view is that manufacture of separate bulb and fixture may require substantially more resources than the single combined product. And assuming a 50,000 hour life, for a product like tree decoration it may be more sustainable to do the combined approach.
Your larger point is correct, though. Longer service life and repairability are generally characteristic of more-sustainable design, and therefore desirable.
Based on???? The di/dt through the filter capacitor is almost independent of output power, it is defined by switching frequency, rail to rail swing, inductance and capacitance.At typical output power probably almost forever.
But let's get back to the OP's question shall we? I have an 18 month old Hypex NC-252MP sitting here on my bench. Dead. Built 41st week of 2019. Sent to me by an ASR member to investigate why it failed as it had a very easy life in a multichannel amplifier. The brand and the member will stay anonymous as he was very happy with their customer service in rapidly rectifying the situation to his satisfaction.
Let's have a quick visual inspection to see if anything stands out.
I can immediately see some very dodgy hand soldering on the SMPS primary side switching transistors and some of the output MOSFETS, because these are the parts done by humans. Regardless, it should have never left the factory with soldering this poor. I think I am onto something:
Also, the board is clearly under a lot of strain (it bends) due to the screwing down of the PCB to the heat-spreader near the heat producing SMPS switchers:
The board bends enough to be 0.76mm out of alignment and the devices are no longer firmly pressed against the heat spreader:
The screws are also too far away from the devices and the impregnated heat transfer pad is too thick. (approx device package positions marked in red). They should not be using distantly mounted fixing/screw points and relying on the flexible PCB to maintain adequate device to heatsink contact. This is bad design 101.
First of all, let's dismantle the sucker and remove the heat-spreading aluminium plate and have a look-see:
Yes, you guessed it! It's gone fully Chernobyl!
Vaporised SMD components hanging off the primary side SMPS switching transistors. Basically, The board flexes under pressure (from the squishy "thermal" pad), so the transistors (FETs) are not adequately thermally coupled any longer to the aluminium spreader. They eventually fail from over heating (these particular devices are both internally shorted) and they take out some associated components around them:
A real mess. There's even a poor SMD transistor with its package cover blown right off. You can see the junction components! And a nice vaporized resistor or two, along with those poor MOSFETs that gave up due to their inability to get rid of heat.
All due to inadequately or properly mounting (you know, with screws, nuts and washers) and heatsinking the transistors. Hypex are simply squashing the devices against the aluminium plate, using plenty of PCBs screws and a foam heat pad, but not considering PCB material deforms under heat and pressure over a (short) period of time.
In my opinion, all the NC-252MPs will likely suffer the same fate in years to come, if this key section is not revised. Not remotely good engineering at all and certainly not likely to last the length of time customers deserve.
Apart from this glaring design fault, the rest of the board is of good quality. The components are adequate and very nicely laid out. I do not like TO220 heat producing devices squashed under pressure from PCBs. It doesn't work. It creates more problems than it saves money. And all the secondary rectifiers and output stage FETs are the same unfortunately.
Hypex can do a whole lot better if they are selling supposedly state of the art equipment. 18 months lifetime for an entire 250WPC module including PSU is just not remotely good enough.
I've had the opposite experience with outdoor Christmas lights strings. Longest lasting was a bit less than 3 years. 2 failed in less than one monthMy fixed LED strings from 5+ years ago are still going strong. The ones from last year with replaceable bulbs are in the garbage.
My LED outdoor light strings, 5 or 6 I think, are going strong after at least 5 years I think. So much less hassle than the old ones, and no broken bulbs to deal with.I've had the opposite experience with outdoor Christmas lights strings. Longest lasting was a bit less than 3 years. 2 failed in less than one month
Who would be the manufacturer of a "forever" capacitor?forever
"For every 1,000 marriages in the last year, only 14.9 ended in divorce, according to the newly released American Community Survey data from the Census Bureau. This is the lowest rate we have seen in 50 years. It is even slightly lower than 1970, when 15 marriages ended in divorce per 1,000 marriages."
Have you tried bybassing the rotary power switch?OK - so another Class D amplifier module bites the dust!
Yes, I checked that. It's turning on but just humming loudly - and pushing the speaker cones out to do it. It does not pass signals at all - just hums and makes you want to make it stop.Have you tried bybassing the rotary power switch?
Unless they are pretty beefy, most rotary switches aren't designed to deal with much current, 3A perhaps, I wonder if the switch has failed.
For something like a power amp, for longevity I would typically use a switch rated at 16A @ 250v AC for the mains: https://cpc.farnell.com/marquardt/1551-3102/rocker-switch-spst-on-off-16a/dp/SW05357?st=16a 250v rocker switch
Why bother? It's a $100 module. Class D modules were destined for the landfill when they were designed/built. Just remove and replace...I would look first at the 2+4 big electro chemical capacitors. Usually it is low quality one.
You need to desolder them and test them with a LCR meter.
It is not easy to desolder because they are glued.
Which makes me come to think about the future stuff. With globalism contact(s) list(s) and futuristically thinking very progressive companies. The sky really is the limit.Why bother? It's a $100 module. Class D modules were destined for the landfill when they were designed/built. Just remove and replace...
