I'm just talking about fidelity of the sound and probably we can't really hear that anyway.
I'm not sure. This site (ASR) likes to mainly talk about objective stuff, so I shared some measurements above and stayed away from sound quality.
Sometime software algorithm implementation can be tricky and not transparent as you can think.
Exactly.
Bad is too much but i'd like to know that conversion is not intrusive in that sense.
In that consideration you do 2 things.
1) convert PCM to DSD
2) feed the DAC with DSD
Both can be responsible for that better behaviour.
Maybe they already know that conversion can't be responsible for that behaviour but I don't know that.
Maybe it's my ignorance about DSD but I Just like to understand and learn more.
I'm not a "believer" when it comes to DSD, the contents needs so much (quantization) noise filtering that for me the most likely explanation for a "nicer sound" is that we like the sound of those filters!Newbie here. I'd like to know the difference in sound quality between the "DSD direct" path (no digital volume control; supported by some AKM-based DACs, such as RME ADI-2 DAC) and the normal path (with volume control); but there seems to be nobody talking about this (neither here nor other forums).
the luxury of a higher signal bandwidth allows for gentler low-pass filtering and keep aliasing artifacts way above audible ranges.
DSD64 yes, but DSD256?
Quantization noise is pushed quite high no? Easier filtering? Simpler analogue section design?
Like this:
DSD makes the D/A converter simpler, easier to implement.
Overall, HQP is well implemented, but too many choices leads to spending too much time comparing settings with tiny or non-existent differences.
For some DACs, DSD is easier to process, so it may be an option to reduce some measurable distortions.
Noted, this is the same thing I hinted.
Not sure. I haven’t changed settings for a year... probably depends on the person...
I said the exact same thing... and limited my comments to the DACs measured above...
I’ve measured a few other DACs that support PCM and DSD.
Which ones bypassed internal DSP for DSD?
We’ve discussed ESS chips in this thread but they don’t have a way to bypass DSP with DSD.
Not many AKM chip DACs support “DSD Direct”.
Just couple examples.
Holo Spring.
Of the two , only this has DSD DSP bypassed.
And Miska has shown it does measure better fed DSD256, than PCM44.1 with it’s internal OS.
Spring2 even better again, I’ve seen.
Note I haven’t made any claims about audibility anywhere... just talking improved measured performance.
As I said, it measures better above audible frequencies.
If you believe that ultrasonic content is important
Jussi has said:
"Because those high frequency high level directly correlated components easily generate intermodulation products in the audio band, down to 0 Hz..."
Amir recently hinted ultrasonic content can impact audible range distortion too (d50s comment):
You can conjecture about high frequency IMD reflecting into the audio band all you want, but if the resulting distortion is below -100dB, I’m willing to ignore it.
Not conjecture from me... Amir raised it as a possibility too, just a few days ago... not in the context of DSD but ultrasonics generally when discussing distortion in audio band of D50s...
