bkjernisted
- Joined
- Aug 21, 2022
- Messages
- 52
- Likes
- 5
As well can I hook a transmitter up to the 3.5 mm port and play the speaker wirelessly?
Yes.Can a Qudelix 5k amp be plugged into a Tribit Stormbox speaker and drive it with the Qudelix equalizer.
I don't understand. You mean a transmitter like the Qudelix 5K?As well can I hook a transmitter up to the 3.5 mm port and play the speaker wirelessly?
Yeah that should work. Lots of conversions in that chain though, so audio fidelity might take a hit.The Qudelix 5 k receives music from bluetooth devices like phones for example. If you were to plug a transmitter into the 3.5 mm output could you not send music wirelessly to a bluetooth speaker. Here is a small transmitter/receiver...no LDAC though
Definitely not.So plugging a 3.5mm cable into the Qudelix 5k and into the speaker will not damage the Qudelix 5k?
Thanks Berwhale. I will post if I get it working.
Berwhale, I just sent the info to my friend. If you go to google play on an android tv, does the addon say it will install on the tv. Thanks for your effort. I appreciate it.
Brent
