At the outlet, it can be tens of watts, but it tends to be less than you'd guess from the power ratings of the amps. I did a few tests with a kill-a-watt type meter a while back. This was for a ~100w class D amp at full blast playing bass-heavy music. I managed to get it into the high 30s.Does anyone have any idea what the actual power consumption of an amplifier is, playing music?
Idle consumption on an NC500 monoblock is 12W.
I think if you're going with efficient horn-type designs and you don't want rave-level bass, then you can probably get away with a 50w or so amp which I'd guess will only be pulling an average of 20ish watts from the outlet during the events, at most. There are plenty of portable power banks that can do this. Even if you go with lithium ion, a 100W / 150wH power bank is only about $100, and this should get you at least a couple hours.
The only thing you really need to concern yourself with is bass efficiency and desired output. Especially because it's outdoors, the bass will tend to be weak and even if you don't need "a lot of" bass, you might not be satisfied with a truly low-power setup.
But I guess you can probably get "high power" with an actual draw of only 50w or so. It's only when you get to PA/Concert levels of bass that you really need a lot of juice.
The rest of the power draw is a rounding error in comparison. I would guess that the idle losses dwarf the actual power draw for >300hz or so.
