RandomFactoid
- Joined
- Dec 12, 2023
- Messages
- 2
- Likes
- 0
(reposting from FB)
Hi! First post here
We might refurnish our lounge where I currently have a pair of DIY Paul Carmody's Amigas. It's a small room (4.8x3.5m) with not very high ceiling either (typical British architecture..).
I might need to switch to bookshelf speakers instead of floorstanders due to space and thought you'd have some suggestions.
Main use - watching movies, but occasionally just stereo playback.
My ideas so far:
1. KEF LS50 - I like the looks, but it seems like the audiophile community is quite split about how good or bad they are. Would be a simple solution as no DIY required (where's the fun then..?)
2. DIY something. If I do, I'd like something more 'high end'. Ideally something that's tried and tested and can easily be upgraded to home theatre if needed by adding a center channel, surrounds, etc. Hypothetical budget.. let's say £/$/€1000. I have read very good feedback about these:
https://philharmonicaudio.com/BMR.html
...but Meniscus Audio, who I believe, used to sell kits, have closed.
What would you build ?
WhateverI decide, the speakers will have to stand pretty close to the fron wall and will probably be quite close to side walls. Not ideal, but that's where we are atm.
Thanks
Hi! First post here
My ideas so far:
Thanks
