How to gently ask: Is the following true or false?
Setup: 1 pair of active speakers.
I add a powered sub-woofer, or a pair of subs (the subs would match, as best as manufacturing tolerances allow).
So now I have a stereo sound system with 2 amps, or 3 amps if I've added a pair of subs.
I have zero confidence that the gain stage of the speaker amp matches the gain stage of the sub-woofer(s). (OK, I could get lucky, but...)
The system is controlled by a single pre-amp (say, an internal pc sound card, or some iteration of the miniDSP Flex).
I hook up the subs, turn on the "system", crank to a happy listening level, and then match the listening level (volume) of the subs to the listening level (volume) of the speaker pair, so that I realize a balanced output.
My system sounds great to my ears (let's just imagine that this is true).
Now, when I raise or lower the volume knob on the pre-amp, the sound from the sub-woofer(s) will be louder or softer than the sound from the speakers,
because the amp in the sub(s) doesn't match the amp powering the speakers, and the music will be bass-heavy or bass-light, and as a consequence, my system will not sound so good. IOW, my system will only sound great at that initial (single) volume level.
Is this true?
Thank you for any insight.
Is this true?
