At which sound pressure levels are loudspeakers calibrated to achieve a flat perceived loudness curve?
dasdoing
Salvador-Bahia-Brasil
Beethoven did not tell pianists to hit the middle keys gently and the lower and upper keys hard during ppp.
you don't get what he is saying. the pianist will play the bass notes as hard as necessary in order to sound balanced with the middle tones. not because he is thinking about loudness contours, but because he is listening.
it's a bad example anyways, pianos have no bass lol. they fake it
Sokel
Not exactly.
A0 of a piano is near 30Hz and the string used is sometimes 2 meters long.
That's genuine bass.
Sokel
it's there, but not audible.
unless you can show me an example
You can play it yourself (I hope I got a good sample):
(note that an extreme piano like this is an octave lower than what you will hear in the attached sample)
  • Piano.ff.A0.zip
dasdoing
fpitas
Northern Virginia, USA
There's no circle of confusion. The mixing engineer cannot encode a loudness curve into mix. Ends.
Lol yes. Somehow this silly thread marches on, though.
Sokel
that one is much better. still we don't really hear anything below that 53Hz one, right?
still, this piano has bass, yes
When you're close and hit hard enough you can even feel it with Grand pianos.
Specially if you hit a strong A-C#-E (A major chord) down there.
Difficult to capture though,at least to me with completely amateur gear.
Mnyb
Sweden, Västerås
The RME DAC’s has the capacity to calibrate the levels at which various loudness compensation should kick in.
So you can decide at which volume level your system should return to flat .
Then you can calibrate this to be somewhat useful, much better than the crude on/off loudness of old.
Loudness curve much be varied for each playback volume. RMe helps with that .
Your ofcourse have no idea of how loud it “should” sound .
Here movie soundtrack are much better both you and studio are suppose to calibrate to the same level .
Then the sound can be produced to sound rigth as it’s known how loud you will playback and if deviate and play softer your AVR knows by hove much and for example, as suggested a function like dynamic eq could compensate ( I don’t have such modern adyssey system myself )
A pity music does not have a reference level . Most of the time we play to soft. I have a rare example ofthe opposite.
I have one recording with some kind of early guitar or lute and it’s say on the CD don’t play to loud as the instrument itself is not very loud and would sound unnatural if cranked up .
ZolaIII
Calibration reference in accordance to ISO 226 2003 is 84 dB.
To those who have a button on the amp hit it to those who don't you can try enabling "Loudness" in JRiver trough internal volume control. To those who opese to it well enjoy how ever you like it anyway. There is no accurate preference for bass level anyhow our individual hearing differs to much for that. And that is what equal loudness studies prove the best.
Trell
The RME also has tone controls for easy and quick adjustment on the fly, which I use on occasion.
TSB
NL
Silly is agreeing with a random strawman without adding value to the conversation and then making fun of people who are trying to engage constructively
fpitas
OK, I'll engage constructively: you don't design a speaker, any speaker, in the fashion proposed in the thread title. Happy?
Even the most cursory examination of Amir's speaker testing would reveal that.
Rja4000
Liège, Belgium
I don't know what a "flat perceived loudness curve" exactly means.
For a music that approaches the real musicians performance, I guess you'd need to play at the original level at the microphone position (if the microphones are omni).
Given the studio work was performed also at that level, looking fir a "natural sounding" sound.
fpitas
That's the point here. No effort has been made to somehow calibrate speakers to some perceived loudness curve. You measure them with a microphone and go for flat response.
TSB
NL
I suppose you're talking about passive speakers. There are definitely active speakers with loudness compensation.
Sokel
Always curious about it,I don't think the studio gear in the 50's could do that (at least for peaks) working with big nice orchestras,at least the ones some friends here told me that was used.
So we are talking about moderns ones,right?
