Mr. Haelscheir
- Joined
- Mar 16, 2023
- Messages
- 110
- Likes
- 84
I've seen https://www.audiosciencereview.com/...ad-for-power-amplifier-torture-testing.10298/, for example, and want to clarify whether it is necessarily the case that different amplifier designs that produce the same transfer function through a basic resistive load can when measurably exhibiting high linearity, flat response, low noise or distortion, and low output impedance (high damping factor) be expected to have nigh identical (within audible thresholds) control over the same real audio transducer provided that all these amps are driven within their nominal operating conditions.
From what control theory basics I learned in university, one could have the example of a motor whose position or velocity you want to control with an electronic signal, say, voltage, whereby the control circuit would exhibit a transfer function between the electronic signal and the desired position or velocity parameter. You could also take the transfer function between different nodes of the control system. Such control systems could be open or closed loop with certain benefits and drawbacks. They could also suffer issues with tracking, underdamping, overdamping, or instability due to the controller's parameters' interaction with the properties of the load (e.g. rotor mass). Most audio systems appear to be open loop with the amplifier driving the transducer with no feedback taken from the produced sound or the transducer's displacement.
- By what principle or model is it that these audio transducers would not (or could) benefit from closed loop control or things such as PID control among other topologies particularly involving feedback from the transducer? Or do existing measurements of very low distortion out of transducers driven by reference amplifiers already demonstrate that transducer feedback is completely unnecessary in audio applications? Perhaps this has to do with audio transducers being LTI? E.g. Could incorporating transducer feedback help control a nonideal transducer's resonant modes, force a specific transfer function, or improve its transient response?
- Does having an identical transfer function for the electric/driving signal (with respect to the original audio signal) running between the amplifier and the transducer guarantee identical tracking of the transducer with that driving signal (identical transfer function of the transducer's motion), or can there be other factors beyond the transfer function for the driving signal that may allow different amplifiers exhibiting the same driving signal transfer function to yield a different transfer function out of the transducer? Or if the only way to produce a different transducer transfer function is for the driving signal's transfer function to also differ, by what principle do amplifiers keep their driving signal transfer function invariant (or fail to do so) between different loads?
- In audio, are we designing amps primarily to control transducers "with the firmest grip" and without being disturbed by those loads, or are we striving to design transducers that are best at obeying the amplifier's every command without disturbing the amplifier's operation? Or you could say that it goes both ways.
