estebanelequente
- Joined
- Jan 7, 2022
- Messages
- 6
- Likes
- 1
Here is my situation.
I have a 7.2.4 Dolby atmos system. My front soundstage are all 4 Ohm Martin logan Speakers.
Before you tell me I am listening too loud, I know I am, but that is how I like my movies. I have noticed that when I whatch a particularly dynamic movie my front soundstage clipps. I have identified that it is likely clipping and not the speakers distorting because I purchased a [email protected] anthem amp for my Mains (Martin Logan Theos) and the clipping stopped on them. I hoped that this would cure the clipping coming from Martin Logan Motion C2 Center since I thought I was removing the most power hungry speakers from the equation. however I am hearing the same thing only in the loudest portions of extremely dynamic movies (Bladerunner 2049, Godzilla vs Kong, Mad Max Fury Road etc.). The rest of my system consists of 8 ohm speakers with the exception of my Logan Center. I am maxed out on my current AVR the Denon X3700H which is rated at 105wX2 at 8 Ohms. However I can not find the all channels driven specs for 8 ohms much Less 4 ohms. I have a lead on an inexpensive older adcom 5 channel amp (GFA 6000) that is rated at 150w at 4 ohms all channels driven on the 3 channels. but only 60w at 8 Ohms for the other 2. Its about $250. My issue is what I am getting with the denon with 9 channels driven is a total unknown but I feel like If I even borrowed 3 channels of amplification I am removing enough stress from my AVR to avoid the clipping. But Will I? and am I just trading watts considering I wouldn't be stepping up substantially? If all things are equal the 5 channels driven rating at 8 ohms on the Denon is 100w based on ASR then 6 ohms jumps to 1% THD. But Im running 9 right now and 1 of those is a 4 ohm speaker. The 100w 8 ohm rating on the adcom is the same with lower distortion on the adcom, the transformer is much bigger and I have a known 4 ohm value at a much lower distortion and would imagine benefit from more current or better circuitry. But I don't know enough and a 200W X3 or [email protected] amp is outside of my budget at the moment. I may have the option to buy and try with very little risk since it is sold locally by a vintage stereo shop. But I am curious what the brilliant minds here have to say on the subject. Also does anyone have a clue what the input sensitivity is on the adcoms of that era? It isn't in the manual.
