Hello!
I'm hoping some of you knowledgeable audio scientists might be able to lend a helping hand with selecting a new reference monitor for my measurement setup.
As the title suggests, I'm looking for information about monitors that offer clean deep low end.
I have been mainly looking into 8" monitors as those i have found with 10" woofers are so much more expensive. The issue is that distortion levels generally spike below about 40Hz and I really need accuracy all the way down towards 20Hz.
(Edit: 20Hz is not the be all end all. I "need" to push a bit of air deeper than 35Hz without going up to 50% THD... i should have phrased it differently, or emphasized the "towards" 20Hz i guess)
I understand that this is not practically possible, but maybe i can get some support in finding the best way forward. Any 8" that particularly shines in terms of low distortion at the extremes of the audio spectrum? Any affordable 10" out there that i have missed?
Price range is approximately 1000$
To avoid future questions:
This will be used mainly, if not only, for engineering work involving analyzing single frequencies. So a lot of parameters that are important for music is not an issue this time around. What I need is something that can deliver power with minimal distortion throughout the audible range.
I would use a sub but i really need focused and predictable projection characteristics as well (my old Genelec S30 are a bit too unpredictable in this regard). Measuring microphone directivity is on the agenda..
Note that this is not about monitors having loads of low end straight out of the box. I do automated frequency correction EQ with very high resolution. This is about having the highest possible clean headroom.
Any help is highly appreciated!
Cheers
Cheers
